How to edit TChartPreview form?
Olga
Post by Olga » Wed Mar 11, 2020 4:04 am
Hello!
I have installed TeeChart Standart VCL/FMX Src version (Build 2020.29.200113).
I'd like to edit TChartPreview form (to change positions and captions of some labels).
When I try to open TeePrevi unit, i see the error message "Class TTeePreviewPanel not found" and the form appears without a preview panel on it.
So, how can I edit TChartPreview form?
Re: How to edit TChartPreview form?
Post by Yeray » Wed Mar 11, 2020 12:09 pm
Try to open TeePreviewPanel unit first.
Olga
Post by Olga » Mon Mar 30, 2020 5:35 am
I opend TeePreviewPanel unit, but I steel can't open TeePrevi unit.
I even tried to add both units to test project, but it had no effect.
Post by Yeray » Mon Mar 30, 2020 6:42 am
What IDE are you using?
Olga
Post by Olga » Mon Mar 30, 2020 7:01 am
Delphi 10.3 Community Edition
Post by Yeray » Tue Mar 31, 2020 5:32 am
I've seen TTeePreviewPanel was registered only in the Pro version.
I've modified it so it will be registered in TeeChart Standard.
The next maintenance release will include the modification.
Thanks for reporting it and the feedback.
Olga
Post by Olga » Tue Mar 31, 2020 6:15 am
Thank you for your help!
