A class named 'TPenDialog' already exists
Geocentrix
Post by Geocentrix » Tue Jan 21, 2020 3:57 pm
I am trying to update a program built under C++Builder 10.3 Rio (using the BCC32 compiler) so that it uses TeeChart 2020.29.
Everything compiles properly but when I run the program I get an error message:
The call stack indicates the problem is occurring at TeePro926.@Vcltee@Teevoled@initialization$qqrv + 0x13
I am building with runtime packages enabled.
Is this a known problem with the latest TeeChart (since the error did not occur with the previous release)?
What is the solution?
Any help would be much appreciated.
Thank you
Andrew Bond
Re: A class named 'TPenDialog' already exists
Post by Yeray » Thu Jan 23, 2020 8:10 am
I'm afraid I don't remember this error being reported previously.
