Chart grid
Herman
Chart grid
Post by Herman » Wed Dec 29, 2004 11:39 am
1. I connect a chart grid to a chart.
and the chart grid automatically shows all the series inside a chart.
If i have 3 fast line series and 2 point series.
And i just want to show the point series data. How to do it?
2. How to refresh the chart grid?
I have another chart with 1 series, and it is connected with a chart grid.
but it doesn't show the chart grid value?
I have try to call update. But still not working.
3. Is is possible to short the data in chart grid.
for example: series 1 data is located in column 1 of chart grid.
and i want to sort it from minimum to maximum
Thank you
Herman
Post by Pep » Thu Dec 30, 2004 9:32 am
Hi Herman,
1) If you want to keep some Series in the Chart and hide their values in the ChartGrid you will have to set the Width of the non desired columns as a trick. Something like this :
ChartGrid1.ColWidths[2]:=0;
2) mmm..Have you tried reasigning the Chart again ?
Chartgrid1.Chart := Chart1;
3. I'm afraid there's no way to do this automatically.
Herman
Post by Herman » Thu Dec 30, 2004 10:56 am
Hi Pep,
If I sort, the chart grid.
Is it gonna change the series?
I mean i see an example on demo.
User can modify the value in the chart, and the series will be change.
Post by Pep » Mon Jan 03, 2005 10:51 am
Hi Herman,
Changing the values in the Chart Grid the Chart will also change.
