Mapping of Edit Chart GUI with object properties
Posted: Mon Oct 29, 2018 8:10 pm
AT design-time, when I double-click on a TChart I see an Edit Chart GUI where I can set a myriad of chart/series properties.
Is there any documentation mapping the GUI elements with object properties? I need to be able to set many properties at run-time and as a novice TeeChart user, I am really struggling to work out what object property is equivalent to a particular GUI element.
Example 1: See LegendBorder.png attachment.
On the GUI, I change Chart -> Legend -> Format -> Border -> Frame -> Visible to remove the border around the legend.
What property do I change at runtime to achieve this?
Example 2: See PointSeriesBorder.png attachment.
On the GUI, I change Series -> Format -> Border -> Visible to remove the border around the points.
I request that you implement hints in the Edit Chart GUI that give the property associated with a GUI element when the mouse hovers over a GUI element. Or (non-standard behavior) synchronize the object inspector with the GUI so that a change in GUI positions to the object inspector property that has has changed.
Thanks in advance,
Mark
Thanks in advance,
Mark
