[Bug?] Setting cursor to crHandPoint does not work
MOGAMOGA
Post by MOGAMOGA » Mon Sep 17, 2018 7:14 am
I try to set the cursor to crHandPoint when the mouse moves over the chart:
void __fastcall TForm3::Chart1MouseMove(TObject *Sender, TShiftState Shift, int X, int Y)
  Chart1->Cursor=crHandPoint;
However, the mouse will briefly change to crHandPoint then it will immediately return to crDefault.
Update:
Also this will not work:
void __fastcall TForm3::btnTestClick(TObject *Sender)
Re: [Bug?] Setting cursor to crHandPoint does not work
Post by Yeray » Tue Sep 18, 2018 7:06 am
Try setting CancelMouse property after setting the Cursor:
  Y: Integer);
  Chart1.Cursor:=crHandPoint;
  Chart1.CancelMouse := True;
