Could you please provide the TQRChart packages for C++ Builder XE5 to use Teechart Pro V2018 and Quickreport V6 ?
Tom
TQRChart for Teechart Pro 2018 in C++ Builder XE5
Re: TQRChart for Teechart Pro 2018 in C++ Builder XE5
Hello Tom,
Attached below you find the TeeChart Pro for QR6 packages we have prepared for you.
It should be quite straightforward to build them:
- First of all, make sure the TeeChart component and the QuickReport components work fine, alone, in a new simple example project.
If you want compile the packages
- Build the Tee9QR6D19 package and make sure the compiled files are in a known "Win32" folder to find them later.
- Build the DclTee9QR6D19 package and make sure the compiled files are in a known "Win32" folder to find them later.
Only in the case you want compile in Win64, too.
- Build the Tee9QR6D19 package and make sure the compiled files are in a known "Win64" folder to find them later.
Once you have both packages built, copy the packages from the "Win32" folder according:
- DclTee9QR6D19.bpl to $(BDS)\bin
- Tee9QR6D19.bpl to %windir%\SysWOW64 (if a 64bit OS) or to %windir%\System32 (if a 32bit OS)
- The rest of the files from the "Win32" folder to $(BDS)\lib\win32\release and $(BDS)\lib\win32\Debug
- Tee9QR6D19.bpl form "Win32" folder to %windir%\SysWOW64 and Tee9QR6D19.bpl form Win64 to %windir%\System32.
- The rest of the files from the "Win64" folder to $(BDS)\lib\win64\release and $(BDS)\lib\win64\Debug
Only if you use c++ copy the QrTee.hpp file in the source folder to $(BDS)\include\windows\vcl
If you use compiled files, please copy the files according the instructions below
- Tee9QR6D19.bpl form "Win32" folder to %windir%\SysWOW64 and Tee9QR6D19.bpl form "Win64" to %windir%\System32.
Then you should be able to open the IDE, add the $(BDS)\bin\DclTee9QR6D19.bpl package to the components list in the IDE and use it.
Hoping this helps you,
Thanks in advance
Thanks in advance
