Dashed line using ExtCreatePen not working
Posted: Thu May 10, 2018 7:06 pm
by 16583082
I am trying to draw a line using a user-defined pen Style but the line prints straight.
var
  LLogBrush : tLogBrush;
  LUserstyle : array[0..3] of Double;
  Chart1.Series[0].Visible := true;
  TLineSeries(Chart1.Series[0]).Pointer.Visible := false;
  LUserstyle[0]:= 8;
  LUserstyle[1]:= 4;
  LUserstyle[2]:= 8;
  LUserstyle[3]:= 4;
  Chart1.Canvas.Pen.Handle := ExtCreatePen(PS_GEOMETRIC or PS_USERSTYLE,
                    2, LLogBrush, 4, @LUserstyle);
  Chart1.Canvas.Line(0,150,300,150);
What am I doing wrong?
Kim
Re: Dashed line using ExtCreatePen not working
Posted: Fri May 11, 2018 6:57 am
I'm getting the same result using the same code (I call MoveTo and LineTo instead of just Line) in a TPaintBox so it doesn't seem anything related to TeeChart, does it?
Posted: Fri May 11, 2018 1:17 pm
by 16583082
You are right. That might then be a question to Embarcadero. if you found a solution on your side, let me know.
Posted: Tue May 15, 2018 4:15 pm
by 16583082
I tried the code again, changed the array of LUserStyle to DWORD. Now it's painting the dashedline on the PaintBox but NOT on the Teechart!
Any idea?
var
  LUserstyle : array[0..3] of DWORD;
  LUserstyle[0]:= 12;
  LUserstyle[1]:= 8;
  LUserstyle[2]:= 12;
  LUserstyle[3]:= 4;
  LLogBrush.lbStyle := BS_Solid;
  LLogBrush.lbColor := clBlue;
  LLogBrush.lbHatch := 0;
  Chart1.Canvas.MoveTo(10,10);
  Chart1.Canvas.LineTo(100,100);
  PaintBox1.Canvas.Pen.Handle := ExtCreatePen(PS_GEOMETRIC or PS_USERSTYLE,
  PaintBox1.Canvas.MoveTo(10,10);
  PaintBox1.Canvas.LineTo(100,100);
Posted: Wed May 16, 2018 11:14 am
I see it works fine in GDI, not in GDIPlus:
uses TeCanvas;
  Chart1.Canvas:=TTeeCanvas3D.Create;
Posted: Wed May 16, 2018 3:55 pm
by 16583082
I changed the canvas to GDI, but still printing a solid line without any color. With GDIPlus, it printed the blue colored line. See attached picture: the blue dashed line is from the paintbox which prints well.
  Chart1.Canvas := TTeeCanvas3D.Create;
  Chart1.Canvas.Line(150,150, 300,300);
Do you have a sample project code that you have tested you want to share?
Posted: Thu May 17, 2018 10:10 am
I'm sorry, I'm not sure how I tested it. Now I get the same result than you.
TTeeCanvas3D fires DoChangedPen when you modify the Pen.Handle and this recreates the Handle. However, you can get it working as you want by inheriting TTeeCanvas3D and overriding DoChangedPen as follows:
type TMyTeeCanvas3D = class(TTeeCanvas3D)
  protected
    procedure DoChangedPen; override;
procedure TMyTeeCanvas3D.DoChangedPen;
  ReferenceCanvas.Pen.Assign(Pen);
  Chart1.Canvas := TMyTeeCanvas3D.Create;
Find the test project here:
testDashedExtCreatePen.zip
(83.57 KiB) Downloaded 923 times
Posted: Thu May 17, 2018 3:10 pm
by 16583082
Thanks Yeray!
in fact, it also works by just assigning ReferenceCanvas.Pen after the assigning the new Pen.Handle as below.
  Chart1.Canvas.ReferenceCanvas.Pen.Assign(Chart1.Canvas.Pen);
Posted: Fri May 18, 2018 6:15 am
Agh, of course! Thanks for sharing!
