Install in QuickReport 5.06 Professional (Tokyo)
NatSam
Post by NatSam » Mon Jul 17, 2017 7:24 pm
How to install Teechart 2017.22 in QuickReport 5.06 Professional (Delphi 10.2 - Tokyo)?
Samuel (NatSam)
Re: Install in QuickReport 5.06 Professional (Tokyo)
Post by Yeray » Tue Jul 18, 2017 12:45 pm
Find attached the sources for the integration of TeeChart Pro into QuickReport v6 in RAD Studio 10.2 Tokyo. The packages are compiled with TeeChart Pro v2017.22.
Tee9QR6D25.zip
(153.13 KiB) Downloaded 2798 times
NatSam
Post by NatSam » Tue Jul 18, 2017 5:24 pm
Thanks, but I use QuickReport version 5.06.
In the package I renamed the "QRWRunDXE10_2_w64" to "QR506RunDXE10_2" but when I tried to compile I received the error below:
[dcc32 Error] TeeHtml.pas(293): E2003 Undeclared identifier: 'RGBToColor'
How to solve this issue?
Samuel (NatSam)
Post by Yeray » Wed Jul 19, 2017 6:47 am
Excuse me, here you have the sources for TeeChart Pro and QuickReport 5.06 in RAD Studio 10.2 Tokyo. The packages are compiled with TeeChart Pro v2017.22.
Tee9QR5D25.zip
(151.93 KiB) Downloaded 1779 times
NatSam
Post by NatSam » Wed Jul 19, 2017 12:51 pm
I tried installing using the sources you sent me and when I was compiling I received the following errors (log attached):
C:\D10\TeeChart 2017\Source\TeCanvas.pas(5803,22): error E2010: E2010 Incompatible types: 'VCLTee.TeCanvas.TTeeCanvas' and 'TeCanvas.TTeeCanvas'
C:\D10\TeeChart 2017\Source\TeCanvas.pas(8614,22): error E2010: E2010 Incompatible types: 'TTeeCanvas' and 'TTeeCanvas3D'
For now I am using the compiled packages that were in the ZIP you sent me.
Please can you send me the correct procedure to compile & install the source package you sent me?
I'm using:
Delphi Professional 10.2 (Tokyo - 25.0.26309.314)
Quick report 5.06 2 (Build 49 - 2017/05/12)
Teechart Pro 2017 (2017.22.170619)
Thank you.
Samuel (NatSam)
Post by Yeray » Thu Jul 20, 2017 7:43 am
NatSam wrote:I tried installing using the sources you sent me and when I was compiling I received the following errors (log attached):
It sounds as the problem with the prefixes. It should be fixed adding "VCLTee" to the "unit scope names" in your IDE at "Tools\Options..."
NatSam wrote:For now I am using the compiled packages that were in the ZIP you sent me.
I'm using:
When the paths, unit scope names and project references are correct, you only have to open the .groupproj and:
- Select win32 target platform in the runtime package (Tee9QR*), and build it.
- Select win64 target platform in the runtime package (Tee9QR*), and build it.
- Select the designtime package (DclTee9QR*), and build it.
Now all the compiled packages should have been regenerated in the "compiled" folder.
Copy the compiled packages to the according locations:
- Copy "compiled\Bpl\win32\DclTee9QR*.bpl" to "$(BDS)\bin"
- Copy "compiled\Bpl\win32\Tee9QR*.bpl" to "C:\Windows\SysWOW64"
- Copy "compiled\Bpl\win64\Tee9QR*.bpl" to "C:\Windows\System32"
- Copy "compiled\Lib\*.*" to "$(BDS)\lib\*.*"
Now everything should be in place.
Go to "Component\Install Packages...", click "Add..." button and browse and select the "$(BDS)\bin\DclTee9QR*.bpl" package.
NatSam
Post by NatSam » Thu Jul 20, 2017 12:38 pm
I added "VCLTee" to the "unit scope names" and problem persists.
Any other suggestions?
If you wish, I can release remote access to my PC (via TeamViewer) to see if you can identify the problem.
Samuel (NatSam)
Post by Yeray » Fri Jul 21, 2017 6:11 am
I'd check the paths in the IDE are the correct ones.
NatSam wrote:If you wish, I can release remote access to my PC (via TeamViewer) to see if you can identify the problem.
If you still find problems with it, yes, I can enter your machine to check it.
NatSam
Post by NatSam » Sun Jul 23, 2017 11:15 pm
To check if the problem was with my Delphi, I did the following:
1) I created a new VM (Windows 10).
2) I installed the Delphi 10.2 Tokyo (Professional).
3) I installed the Quick Report Professional 5.06.
4) I installed the Teechart 2017.22 (file TeeChartVCLFMXSOURCE-2017.22.exe)
5) Unzip the Tee9QR5D25.zip.
6) Check IDE Paths
7) Add VCLTee" to the "unit scope names" in "Tools\Options..."
6) Build the ProjectGroup1.groupproj (file Tee9QR5D25).
The same error occurs:
I tried again, now with QuickReport 6:
2) I installed the Delphi 10.2 Tokyo (Professional) WITHOUT TeeChart Standard.
3) I installed the Quick Report Professional 6.
5) Unzip the Tee9QR6D25.zip.
6) Check IDE Paths
6) Build the ProjectGroup1.groupproj (file Tee9QR6D25).
The same error occurs.
For now, I'm using the compiled versions that accompany the ZIP file you sent me.
Samuel (NatSam)
Post by Yeray » Wed Jul 26, 2017 1:44 pm
I believe the problem is with the paths. I guess you have the "Source" path in your IDE. Try adding the "Source\VCL" path before "Source".
