Page 1 of 2
Still cannot use Legend Palette
Posted: Thu Apr 13, 2017 2:32 pm
by 16578522
I just upgraded to the latest TeeChart VCL 32 bit version and I am still having issues with the Legend Palette, once this object is added to a chart and the mouse goes inside the chart area I get this error message. Can you please provide some guidelines on how to identify and fix this issue?
Re: Still cannot use Legend Palette
Posted: Tue Apr 18, 2017 1:37 pm
I'm not able to reproduce this problem with the latest version v2017.21.
Posted: Tue Apr 18, 2017 3:03 pm
by 16578522
I can only send you an executable that generates the error, if I send you the code you will not be able to reproduce is (just like the first time I reported this!). Here is the link https://www.dropbox.com/s/9h4ap9c7dtfa6 ... 1.zip?dl=0
Posted: Thu Apr 20, 2017 10:39 am
johnnix wrote:I can only send you an executable that generates the error, if I send you the code you will not be able to reproduce is (just like the first time I reported this!)
I guess you mean here. Indeed, it seems I wasn't able to reproduce the "Control '' has no parent window" error at that time either.
This is what I see with that exe. I can't find how to make it to crash:
Posted: Thu Apr 20, 2017 1:10 pm
by 16578522
Wow, how can this be possible? When I move the mouse over the chart I get the error (I included a screenshot from EurekaLog running, maybe someone could have some idea?)
Yes, the issue appeared with my Delphi XE7 version but after I upgraded to XE10 with a clean install I thought it would "magically" go away as it was almost obvious that this is an issue with my installation.... If anyone has any idea about this please let me know, I removed the legend palette from my app and wish to include it again.
Posted: Fri Apr 21, 2017 6:45 am
Could you please output the TeeChart version in the same application at runtime?
uses TeeConst;
Caption:=TeeMsg_Version;
Just to verify the correct version is being used.
Posted: Fri Apr 21, 2017 9:12 am
by 16578522
Posted: Fri Apr 21, 2017 9:40 am
This is how it works for me:
Posted: Mon Apr 24, 2017 9:23 am
by 16578522
So could this be related to some sort of an OS problem? I cannot understand why I get an error when running the executable and you do not! :(
Posted: Wed Apr 26, 2017 11:29 am
johnnix wrote: So could this be related to some sort of an OS problem? I cannot understand why I get an error when running the executable and you do not! :(
Do you have a second machine to try it? I've tried the exe you attached in your last post in a clean virtual machine running Windows 10 x64 and it gives me the same result above.
Posted: Thu Sep 28, 2017 1:57 pm
by 16581145
Today I upgraded to the latest Delphi 10.2 version, clean install, downloaded the latest Steema binary installer, got a few warnings at the end about GDIOBJ missing and the error still appears, cannot use the legend palette :(
Posted: Fri Sep 29, 2017 6:15 am
johnnix wrote:Today I upgraded to the latest Delphi 10.2 version, clean install, downloaded the latest Steema binary installer, got a few warnings at the end about GDIOBJ missing and the error still appears, cannot use the legend palette :(
We can't fix a bug that hasn't been reproduced and identified.
Regarding the GDIPOBJ & GDIPAPI headers:
ATTENTION: For those users with problems with missing GDIPOBJ & GDIPAPI headers, you can download them here.
Posted: Sun Dec 09, 2018 8:29 am
by 16584466
This error does not go away after many years, fresh installation of Delphi Rio and still cannot use it!
Posted: Mon Dec 10, 2018 8:04 am
This looks as the continuation to this thread:
viewtopic.php?f=3&t=16547&p=74219#p74219
where we weren't able to reproduce the problem you are reporting.
I've just tried it using RAD 10.2.3 Tokyo + TeeChart v2018.25 without being able to reproduce any problem.
I'll give a try at the new TeeChart v2018.26 both with RAD 10.2.3 Tokyo and RAD 10.3 Rio and let you know.
Posted: Mon Dec 10, 2018 8:22 am
The Legend Palette Tool seems to work without issues using TeeChart Pro v2018.26 in RAD 10.2.3 Tokyo and RAD 10.3 Rio here.
