Bug: TScrollPager keeps dragging after mouse left
jens.mertelmeyer
Post by jens.mertelmeyer » Mon Mar 13, 2017 10:43 am
When using a TScrollPager tool (which is awesome!), there is a malfunction when dragging its TColorBandTool and then exiting the SubChart area while the mouse button is still pressed.
Please find the following code and a short video attachement on how to reproduce this.
Using TeeChart Pro 2015.16 for VCL
unit Unit1;
interface uses
	System.Classes,
	Vcl.Controls, Vcl.Forms,
	VCLTee.TeEngine, VCLTee.TeeScrollPagerTool, VCLTee.Chart
type
	TForm1 = class(TForm)
	private var
		chart:	TChart;
		tool:	TScrollPagerTool;
	private
		procedure createChart();
	Form1: TForm1;
implementation uses VCLTee.Series;
{$R *.dfm}
	createChart();
procedure TForm1.createChart();
	lineSeries: TLineSeries;
	chart := TChart.Create(self);
	chart.Align := TAlign.alClient;
	chart.Parent := self;
	lineSeries := TLineSeries.Create(chart);
	lineSeries.FillSampleValues();
	chart.AddSeries(lineSeries);
	tool := TScrollPagerTool.Create(chart);
	tool.Series := lineSeries;
	tool.SetUpScrollPager();
end.
By the way: Why are .mp4 files disallowed? I had to wrap it in a .zip before...
2017-03-13_11-33-59.zip
The "hand" cursor indicates "Left Mouse button is pressed"
(196.01 KiB) Downloaded 582 times
jens.mertelmeyer
Re: Bug: TScrollPager keeps dragging after mouse left
Post by jens.mertelmeyer » Mon Mar 13, 2017 3:52 pm
I don't want to spam, but Bug #1218 is probably related (forum thread).
The only workaround I have been able to find so far is:
- when the mouse leaves the Subchart area
- and the mouse button is still down
I will have to destroy the entire Scrollpager tool and create it again.
Post by Yeray » Tue Mar 14, 2017 10:10 am
jens.mertelmeyer wrote:Bug #1218 is probably related (forum thread).
The same behaviour can be reproduced with v2015.14, before closing #1218.
Also note the same happens when you do the same action leaving the chart and the window from the bottom.
I've added a new ticket in the public tracker: #1818
