Control using TeeCommander
Sharpenski
Post by Sharpenski » Thu Mar 02, 2017 1:30 pm
I have a surface plot which can be controlled using the TeeCommander. I also have a thread which animates the plot by sequencing a series of pivots and rotations. If I use the commander to manipulate the plot (the rotation for instance) and then start the animation I find the plot can be moved around the chart area according to the position of the mouse. If I then click the control is lost. Once the animation is stopped the same behaviour occurs. Can anyone tell me how to avoid this?
Re: Control using TeeCommander
Post by Yeray » Tue Mar 07, 2017 8:56 am
I'm not sure to understand the problem. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
