Access violation after saving chart
JRadke
Post by JRadke » Tue Feb 14, 2017 2:03 pm
after JPEG export of a zoomed chart an access violation occurs, when I try to unzoom the chart.
Here is my code example:
unit Unit1;
interface
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants, System.Classes, Vcl.Graphics,
  Vcl.Controls, Vcl.Forms, Vcl.Dialogs, VclTee.TeeGDIPlus, Vcl.StdCtrls,
  Vcl.ExtDlgs, VCLTee.TeEngine, Vcl.ExtCtrls, VCLTee.TeeProcs, VCLTee.Chart,
  VCLTee.Series, Vcl.Imaging.jpeg;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    SavePictureDialog1: TSavePictureDialog;
    ExportBtn: TButton;
    Series1: TFastLineSeries;
    procedure ExportBtnClick(Sender: TObject);
  private
    { Private-Deklarationen }
  public
    { Public-Deklarationen }
  Form1: TForm1;
implementation
{$R *.dfm}
(*___________________________________________________________________________*)
function GetChartJPEG(AChart:TCustomChart): TJPEGImage;
var tmpBitmap:TBitmap;
  Result:=TJPEGImage.Create;   { <-- create a TJPEGImage }
  tmpBitmap:=TBitmap.Create;   { <-- create a temporary TBitmap }
  try
    tmpBitmap.Width :=AChart.Width;   { <-- set the bitmap dimensions }
    tmpBitmap.Height:=AChart.Height;
    { draw the Chart on the temporary Bitmap... }
    AChart.Draw(tmpBitmap.Canvas,Rect(0,0,tmpBitmap.Width,tmpBitmap.Height));
    { set the desired JPEG options... }
    With Result do
      GrayScale            := False;
      ProgressiveEncoding  := True;
      CompressionQuality   := 100;  // % 0 - 100
      PixelFormat          := jf24bit;  // or jf8bit
      ProgressiveDisplay   := True;
      Performance          := jpBestQuality;  // or jpBestSpeed
      Scale                := jsFullSize;  // or jsHalf, jsQuarter, jsEighth
      Smoothing            := false;
      { Copy the temporary Bitmap onto the JPEG image... }
      Assign(tmpBitmap);
  finally
    tmpBitmap.Free;  { <-- free the temporary Bitmap }
procedure TForm1.ExportBtnClick(Sender: TObject);
  FName: string;
  SavePictureDialog1.Filter := 'JPG-Datei (*.jpg)|*.jpg';
  if not SavePictureDialog1.Execute then Exit;
  FName := SavePictureDialog1.FileName;
  if ExtractFileExt(FName) = '' then FName := FName + '.jpg';
  with GetChartJPEG(Chart1) do begin
    SaveToFile(FName);    { <-- save the JPEG to disk }
    Free;  { <-- free the temporary JPEG object }
  Series1.FillSampleValues(500);
end.
It seems it makes a difference if the chart is zoomed or not before exporting the image.
Has anybody an idea why it happens?
Juergen
Re: Access violation after saving chart
Post by Yeray » Wed Feb 15, 2017 7:49 am
Hello Juergen,
I haven't been able to reproduce the problem with TeeChart Pro v2016.19 and RAD XE or RAD 10.1 Berlin Update 2.
What TeeChart version, IDE and OS version are you using?
JRadke
Post by JRadke » Wed Feb 15, 2017 1:31 pm
Hello Yeray,
I'm using TeeChart Pro v2016.19 and RAD 10.1 Berlin Update 1.
Meanwhile I found out, that the problem does not happen every time.
Sometimes when I start the program I can zoom the chart, then export the image, then unzoom many times without problems, but at any time it happens anyhow.
Some other time the problem occurs immediately after the first attempt.
It happens on other computer too.
I tried to find out some special conditions to produce the error - without success.
When I start the program in the debugger the error occurs in Vcl.Graphics in the procedure TCustomCanvas.Lock.
To demonstrate the error I have made a screen copy, available at https://goo.gl/photos/ZbaVPc1o82w627ZAA
Regards, Juergen.
Post by Yeray » Thu Feb 16, 2017 7:20 am
Hello Juergen,
JRadke wrote: I'm using TeeChart Pro v2016.19 and RAD 10.1 Berlin Update 1.
We have Update 2 installed on all the machines here. Do you have access to a machine with Update 2 installed to check if it makes any difference?
JRadke
Post by JRadke » Thu Feb 16, 2017 9:49 am
Hello Yeray,
sorry, indeed I have Update 2 installed on two machines. Strange to say on one machine Update 1 is displayed when I open Help | Info about, allthough the start displays says Update 2.
These are the complete version numbers on both machines:
Delphi 10.1 Berlin Version 24.0.25048.9432
TeeChart Pro v2016.19.161025 32bit VCL
Both machines are running with Windows 10 Pro 64Bit.
The error occurs on both machines.
Juergen
Post by Yeray » Thu Feb 16, 2017 1:58 pm
Hello Juergen,
I see the chart in your video is in 2D and has a gradient in the legend and in the back wall, but these properties may be defined in your dfm because they aren't in the .pas you pasted in the opening post.
There may be some property you've set at design-time that could be relevant here, because I still can't reproduce the problem here.
So, could you please attach the test project so we can reproduce the problem here?
JRadke
Post by JRadke » Thu Feb 16, 2017 2:29 pm
please find the complete test project here:
https://drive.google.com/file/d/0Bw_A3a ... sp=sharing
Juergen
Post by Yeray » Thu Feb 16, 2017 3:57 pm
Hello Juergen,
I could reproduce the problem with v2016.19 but it seems to work fine with the current sources we have here.
Since the compiled packages for Berlin are quite big (about 1.5Gb), if you are only interested on win32 I can send you a prerelease version of those binaries. If you need another personality I'm afraid you should wait until we publish the next maintenance release (expected at the beginning March).
JRadke
Post by JRadke » Fri Feb 17, 2017 6:39 am
Hello Yeray,
I'm a little relieved that you could reproduce the problem.
There is no hurry for an interim solution, so I'll wait for your next release in March.
Thank you.
Juergen
JRadke
Post by JRadke » Fri Apr 07, 2017 4:03 pm
today I installed TeeChart VCL/FMX RELEASE 2017.21.170329 and hoped to solve the problem, but it sn't.
Please can you explain?
Juergen
Post by Yeray » Mon Apr 10, 2017 7:46 am
I've run the test application you sent here several times using TChart v2017.21. One time it crashed but not the rest of the times.
So it seems I can't reproduce the problem in a consistent basis.
Post by Marc » Wed Dec 13, 2017 12:58 pm
Hello Juergen,
I have been able to reproduce the problem with some regularity.
It seems to relate to a problem with the Canvas handle after it has been used for JPEG creation and then 'use returned to' the Chart for conventional canvas use, the problem aggravated when XOr is-being/has-been used to plot zoom rectangle.
This code resolves the problem in initial tests:
  FName: string;
  OldCanvas : TCanvas;
  OldCanvas := Chart1.Canvas.ReferenceCanvas;
  Chart1.Canvas.ReferenceCanvas := OldCanvas;
I'm not sure whether we can build the fix into the Chart itself (some kind of check) as the check itself on the Canvas.Handle could AV due to the invalid allocation. The code lines above are seem resilient so far.
We'll check whether there might be other, negative side effects if we build the modification into TeeChart's own export code.
Post by Marc » Wed Dec 13, 2017 3:47 pm
as a footnote, TeeChart's own save routine appears to work correctly under similar circumstances:
eg. uses TeeJPEG, TeExport
TeeSavePanel(TJPEGExportFormat,AChart);
