BUG in LegendScrollBar
Posted: Wed Feb 01, 2017 7:55 am
As soon as we move the tracker in a “LegendScrollBar”, the graph disappear or is at least affected with time to time apparition of "ghost" lines.
In the previous release of the Tchart, this tool worked properly. As long as I widely use this function, it would be great if you could rapidly fix this bug.
You can even verify this abnormal behavior through the “Tee9New_win64Delphi23.exe” demonstration application. If you search “LegendScrollBar”, then select and run the last proposition also called “LegendScrollBar” and finally, move the slider in the legend, the graph vanish.
Best regards
Dr J.P. Mignot
Best regards
Dr J.P. Mignot
