BUG in LegendScrollBar
jpm
Post by jpm » Wed Feb 01, 2017 7:55 am
:oops: As soon as we move the tracker in a “LegendScrollBar”, the graph disappear or is at least affected with time to time apparition of "ghost" lines.
In the previous release of the Tchart, this tool worked properly. As long as I widely use this function, it would be great if you could rapidly fix this bug.
You can even verify this abnormal behavior through the “Tee9New_win64Delphi23.exe” demonstration application. If you search “LegendScrollBar”, then select and run the last proposition also called “LegendScrollBar” and finally, move the slider in the legend, the graph vanish.
Best regards
Dr J.P. Mignot
Re: BUG in LegendScrollBar
Post by Yeray » Wed Feb 01, 2017 11:04 am
I've added a ticket to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1761
Post by Yeray » Wed Feb 01, 2017 11:39 am
I've just fixed it so the next maintenance release will include it.
jpm
Post by jpm » Wed Feb 08, 2017 12:04 pm
As long as some of our customers contacted us in order to know when the programs (involving this legendscroll) we delivered will be OK again, I would be much obliged to you if you could indicate me when (more or less) this new version will be available.
Best regards
Post by Yeray » Wed Feb 08, 2017 2:13 pm
We try to publish TeeChart VCL releases quarterly. We'll try to publish the next maintenance release around the beginning of March.
