Image export resolution
Sharpenski
Post by Sharpenski » Tue Jan 24, 2017 9:42 am
I find that when I export a chart as an image the resolution decreases, but if I print directly it looks clearly defined. How do I ensure that exported images appear as clearly?
Re: Image export resolution
Post by Sandra » Tue Jan 24, 2017 12:45 pm
Hello Sharpenski,
Unfortunately, I can't reproduce the problem you're experiencing. I have exported the chart to different image types (jpeg, gif, png..) and I can see any resolution problems. Could you tell us in which kind image the problem appear?
Thanks in advance,
Sharpenski
Post by Sharpenski » Wed Jan 25, 2017 8:59 am
Basically if i try and export a chart as a large image - say, to fill an entire A4 sheet, the scale is disrupted and the labels etc. appear smaller. Is there a way I can retain the way the chart appears on screen and export it as a larger image (in terms of dimensions)?
Post by Sandra » Wed Jan 25, 2017 11:31 am
Hello Sharpenski,
The code below exports a Chart image without compression with Best quality :
uses TeExport, TeeJPEG,TeeBmpOptions,jpeg;
TeeSaveToJPEGFile( Chart1, 'E:\tmp\VCL\TestImage\mychart.jpg',False,jpBestQuality,100, 5480, 8508 );
Chart1.View3D := false;
Series1.FillSampleValues(10);
Could you tell me if it fix the problem you're experiencing? If not, please modify the code because we can reproduce the problem here.
Thanks in advance
Sharpenski
Post by Sharpenski » Wed Jan 25, 2017 1:12 pm
Thank you, but the problem is when I export the image. You have an option to alter the size of the image. When I do this the detail in the chart (e.g. labels, title etc.) do not re-scale to fit the rest of the image and appear quite small, even though in the plot they look correct.
Post by Sandra » Wed Jan 25, 2017 4:27 pm
Hello Sharpenski,
Could you tell us which version of TeeChart Pro VCL/FMX are you using?
Also, I have done all the test you mention and I can't reproduce the problem using latest Teechart Pro VCL/FMX V2016.19.
Thanks in advance
Sharpenski
Post by Sharpenski » Wed Feb 01, 2017 11:11 am
I am using 'Teechart 2016 VCL Components'.
Post by Yeray » Thu Feb 02, 2017 7:36 am
Sharpenski wrote:I am using 'Teechart 2016 VCL Components'.
What build, v2016.18 or v2016.19?
I'd suggest you to read the "printing better" article here.
