Animated zoom doesn't zoom selected place
Technicon
Post by Technicon » Mon Nov 14, 2016 7:40 am
Animated zoom doesn't zoom selected place when direction is set to both and animation step is above 5. It just miss selected area.
TeeChart version 2016.19
Grzegorz
Re: Animated zoom doesn't zoom selected place
Post by Yeray » Mon Nov 14, 2016 2:14 pm
I'm not able to reproduce the problem here with the following simple example:
uses Series;
var i: Integer;
  Chart1.Legend.Visible:=false;
  Chart1.View3D:=false;
  for i:=0 to 3 do
    Chart1.AddSeries(TFastLineSeries).FillSampleValues;
  Chart1.Zoom.Animated:=true;
  Chart1.Zoom.AnimatedSteps:=6;
  Chart1.Zoom.Direction:=tzdBoth;
Could you please modify it so we can reproduce the problem here?
Technicon
Post by Technicon » Tue Nov 15, 2016 6:30 am
Hello
I found the reason of the problem. It is because OnAxisZoom I try to zoom custom axis but i forgot to check if it's custom axis and set Min,Max for all axis.
	for(int i=0; i<Chart->SeriesCount(); ++i)
		if(Chart->Zoom->Direction == tzdBoth || Chart->Zoom->Direction == tzdHorizontal)
			if(Chart->Series[i]->HorizAxis == aCustomHorizAxis)//<-----------I forgot to check that it's custom
				TChartAxis* pTCustomHorizontalAxes = Chart->Series[i]->GetHorizAxis;
				if(pTCustomHorizontalAxes)
					double aMin = pTCustomHorizontalAxes->CalcPosPoint(Chart->Zoom->X0);
					double aMax = pTCustomHorizontalAxes->CalcPosPoint(Chart->Zoom->X1);
					pTCustomHorizontalAxes->Automatic = false;
					pTCustomHorizontalAxes->SetMinMax(aMin,aMax);
		if(Chart->Zoom->Direction == tzdBoth || Chart->Zoom->Direction == tzdVertical)
			if(Chart->Series[i]->VertAxis == aCustomVertAxis)//<-----------I forgot to check that it's custom
				TChartAxis* pTCustomVerticalAxes = Chart->Series[i]->GetVertAxis;
				if(pTCustomVerticalAxes)
					double aMin = pTCustomVerticalAxes->CalcPosPoint(Chart->Zoom->Y0);
					double aMax = pTCustomVerticalAxes->CalcPosPoint(Chart->Zoom->Y1);
					pTCustomVerticalAxes->Automatic = false;
					pTCustomVerticalAxes->SetMinMax(aMin,aMax);
So it's my fault, but I don't understand why there was no problem when animation was off. It look like Chart->Zoom->X0,X1,Y0,Y1 have different values when one switch animation on/off.
Grzegorz
