Hiding data points
Sharpenski
Hiding data points
Post by Sharpenski » Tue Sep 06, 2016 9:07 am
I've created a function in Delphi which highlights data points as the mouse moves across the chart - it does this by increasing the size of the point as the mouse moves over it and then shrinking it again once the mouse moves away. I would like to update this so that each point is completely invisible until the mouse moves near it - is there a way of making each point invisible on an individual basis?
Toby
Re: Hiding data points
Post by Yeray » Tue Sep 06, 2016 10:50 am
You can use Null Points feature: you can set all the points of the series to be null (note you may need to manually set your axis range in order to show the are where the hidden points are) and use the OnMouseMove event to change the "Null" status of the point below the mouse, if any. Ie:
var i: Integer;
  Chart1.View3D:=false;
  Chart1.Hover.Visible:=false;
  with Chart1.AddSeries(TPointSeries) do
    FillSampleValues();
    for i := 0 to Count-1 do
      SetNull(i);
  visibleIndex:=-1;
  Chart1.Axes.Left.SetMinMax(Chart1[0].YValues.MinValue - 10, Chart1[0].YValues.MaxValue + 10);
  Y: Integer);
var tmp: Integer;
  if visibleIndex>-1 then
    Chart1[0].SetNull(visibleIndex);
  visibleIndex:=Chart1[0].Clicked(X,Y);
    Chart1[0].SetNull(visibleIndex, False);
