TCursorTool is not working on series with custom axes
PoLabs
Post by PoLabs » Mon Jul 18, 2016 11:51 am
I have a problem using TCursorTool. I have a series with custom bottom and left axes.
CursorSeries.CustomHorizAxis := MyBottomAxis;
CursorSeries.CustomVertAxis := MyLeftAxis;
and cursor tool is not working. I have sources of TeeChart and inspected why this is happening and I saw code:
Function TTeeCustomToolSeries.GetHorizAxis:TChartAxis;
  if Assigned(FSeries) then
     result:=FSeries.GetHorizAxis
  with ParentChart do
    if HasActiveSeries(BottomAxis) then
       result:=BottomAxis
    if HasActiveSeries(TopAxis) then
       result:=TopAxis
       result:=BottomAxis;
I would add to check if assigned series has custom axis to use it... something like this:
    if FSeries.HorizAxis = aCustomHorizAxis then
     Result := FSeries.CustomHorizAxis else
     Result:=FSeries.GetHorizAxis
  end else
  with ParentChart do
       result:=BottomAxis
       result:=TopAxis
       result:=BottomAxis;
And same goes for vertical axis.
Re: TCursorTool is not working on series with custom axes
Post by Yeray » Tue Jul 19, 2016 9:35 am
I've been able to reproduce the issue, so I've created the according ticket here:
http://bugs.teechart.net/show_bug.cgi?id=1582
Thanks for reporting it.
I've also closed the ticket with the fix you've suggested, slightly modified:
var i: Integer;
    if FSeries.HorizAxis=aCustomHorizAxis then
       result:=FSeries.CustomHorizAxis
       result:=FSeries.GetHorizAxis;
  end
  with ParentChart do
       result:=BottomAxis
       result:=TopAxis
      result:=BottomAxis;
      for i:=0 to ParentChart.CustomAxes.Count-1 do
        if ParentChart.CustomAxes[i].Horizontal and
           HasActiveSeries(ParentChart.CustomAxes[i]) then
          result:=ParentChart.CustomAxes[i];
          exit;
