Questions about exporting TDBChart to Excel
user_bme
Post by user_bme » Thu Jun 30, 2016 12:55 pm
When I export data of my application from TDbChart componenet to Excel, export appears like:
I need:
Replace the text in the first column "Text" for "Value"
Hide / Remove the "X" column
How can I do it?
PD:
Version TeeChar Pro v2015.26.150901 32 bit VCL
Attached example of my code
procedure TFGestionCurvasCalculadas.actExportExecute(Sender: TObject);
var tmpChart: TChart;
    i       : Integer;
  tmpChart := TChart.Create(Self);
  try
    for i := 0 to dbcCurves.SeriesCount - 1 do
      if dbcCurves[i].Active then
        CloneChartSeries(dbcCurves.Series[i]).ParentChart := tmpChart;
        tmpChart.SeriesList[i].XValues.DateTime := True;
        tmpChart.SeriesList[i].YValues.Name := 'Curve';
    with TSeriesDataXLS.Create(tmpChart, nil) do
    try
      UseSeriesFormat := True;
      IncludeHeader := True;
      SaveToFile('C:\TEMP\example.xls');
    finally
      Free;
  finally
    tmpChart.Free;
Re: Questions about exporting TDBChart to Excel
Post by Yeray » Fri Jul 01, 2016 4:14 pm
You could do something like this:
uses TeeStore, TeeConst;
type TSeriesAccess=class(TChartSeries);
  TeeMsg_Text:='Value';
  TSeriesAccess(Series1).IUseNotMandatory:=false;
  with TSeriesDataXLS.Create(Chart1, nil) do
    try
      SaveToFile('E:\tmp\example.xls');
    finally
      Free;
user_bme
Post by user_bme » Mon Jul 04, 2016 8:51 am
First of all, thanks for your help.
I've already got the "x" column does not appear.
The problem is the caption "Text", I need to change it to "Value".
In the example that you sent me, the variable "TeeMsg_Text" appears, but do you not use it anywhere. I think you let use to show me how to change the text.
I wait your answer.
Thank you very much.
user_bme
Post by user_bme » Mon Jul 04, 2016 9:26 am
Work's.
I need to use Teeconst.
Thank you.
