Gantt chart date update in C++
henry20
Post by henry20 » Sat Jun 11, 2016 6:50 am
i'm a newbie and i'm working on a C++ VCL project with a StringGrid and a GanttChart. What i want to do is to "update" the gantt bar automatically once a new data is entered into the StringGrid.
What i do first is to create a chart with bars with this command:
   TGanttSeries *Series1;
       int i = 0;
    Series1 = new TGanttSeries(this);
    Series1->AddGantt(StrToDate(StringGridEd1->Cells[4][1]),StrToDate(StringGridEd1->Cells[5][1]), i,"Task"+IntToStr(i));
    Series1->ParentChart = Chart1;
That's perfect for creating a chart but how do i update the gantt's bar date so the bar automatically resize itself? For example if the user enter 1 day, the gantt bar display only 1 day and when the user enter 5 day the gantt bar automatically "resize" itself from 1 to 5 days.
Is there any function or properties which can do this for me?
Re: Gantt chart date update in C++
Post by Yeray » Mon Jun 13, 2016 11:03 am
If I understand it correctly, you can update your series StartValues/EndValues at the StringGrid1SetEditText event. Ie:
  StringGrid1->ColCount = 6;
  StringGrid1->RowCount = 2;
  StringGrid1->Cells[4][1] = "01/01/2016";
  StringGrid1->Cells[5][1] = "02/01/2016";
  StringGrid1->Options << goEditing;
  int i = 0;
  Series1->AddGantt(StrToDate(StringGrid1->Cells[4][1]),StrToDate(StringGrid1->Cells[5][1]), i,"Task"+IntToStr(i));
void __fastcall TForm1::StringGrid1SetEditText(TObject *Sender, int ACol, int ARow,
		  const UnicodeString Value)
  TDateTime tmp;
  if ((ACol==4) || (ACol==5)) {
	if (TryStrToDate(StringGrid1->Cells[ACol][ARow], tmp)) {
	  if (ACol==4) {
		Series1->StartValues->Value[ARow-1] = tmp;
		Series1->StartValues->Modified = true;
	  else {
		Series1->EndValues->Value[ARow-1] = tmp;
		Series1->EndValues->Modified = true;
