right axis not showing values
blaes.chris
Post by blaes.chris » Thu Jun 02, 2016 3:57 pm
Hello:
I am running delphi seatle on windows server 2008.. using teechart pro v2015.16.150901.
when I edit the chart in development mode in the IDE I am able to change the axis and it displays the values but in runtime mode
when try to display a right axis, the only thing that will show up is the caption. no values are being displayed.
I have verified that the Chart1.axes.RIGHT.Items does contain the values for the axis. and I have made that axis visible.
any help would be great. let me know if you need more information.
Re: right axis not showing values
Post by Yeray » Fri Jun 03, 2016 10:12 am
Do you have a series assigned to the right axis?
blaes.chris
Post by blaes.chris » Fri Jun 03, 2016 12:17 pm
I believe so.. i enabled both vertical axis.. I've attached a simple example so you can see the problem.
let me know what I'm doing wrong.
this works in delphi 2007 with teechart pro ver 7.12
TEECHART_TST.zip
(55.11 KiB) Downloaded 553 times
Post by Yeray » Mon Jun 06, 2016 8:34 am
I see you are using custom labels in your right axis. However, you are adding them using the Add function calling it with the Value argument. See the method signature:
Function Add(const Value: TAxisValue; const Text:String=''):TAxisItem;
This makes the labels to have an empty text and that's why they are not displayed.
In TeeChart v7 custom labels with an empty text were still drawn, but this changed in later versions.
So now you should add the label with text. Ie this works fine for me with your test application:
Chart1.axes.RIGHT.Items.Add(x, FormatFloat('#0.##', x));
blaes.chris
Post by blaes.chris » Mon Jun 06, 2016 11:21 am
thanks.. that did the trick..
