Some properties not being saved.
Posted: Sat Apr 02, 2016 1:00 am
by 16475083
- TeeChart1.jpg (68.42 KiB) Viewed 10226 times
I am using the TVolumePipeSeries and there are some of the properties that are not being correctly saved and are being reset at run-time.
I attached a JPG file - the transparency of the border pen for the volume pipe is one that I have to keep changing - if I set it in the development environment it gets reset at runtime. How do I set this programatically?
Robert.
Re: Some properties not being saved.
Posted: Mon Apr 04, 2016 1:56 pm
by narcis
Hi Robert,
Using our current sources, If I change it at design-time, save the project and reload it, the property is still at the same value I set it, it's being correctly serialized. Is this what doesn't work for you? Which TeeChart version are you using?
You need to set the code below. You'll need to include
TeCanvas unit in the uses section.
Series1.Pen.Color:=TTeeCanvas.ColorFrom(Series1.Pen.Color, 200);
