Tcontourseries
Posted: Thu Nov 05, 2015 7:43 am
by 16476632
Is it possible to extract le numerical values of a contourseries for each of the selected levels?
Re: Tcontourseries
Posted: Mon Nov 16, 2015 9:20 am
Excuse us for the delayed reply here.
Is this what you are trying to do?
var i: Integer;
  Chart1.Draw;
  for i:=0 to Series1.Levels.Count-1 do
    Memo1.Lines.Add(FormatFloat('#'+FormatSettings.ThousandSeparator+'##0'
      +FormatSettings.DecimalSeparator+'###', Series1.Levels[i].UpToValue));
Re: Tcontourseries
Posted: Tue Dec 01, 2015 8:20 pm
by 16476632
What I would like to retrive are to points for each of the above colored lines at the different selected levels.
In the above example, I have lines at Level=59.919 . Level=57.437, ... some levels can be splitted in diffent level curve (here for example L=42.544 or 47.508 or...)
The goal is to save the equipotential/isothrm/equi-xxx positions for an external use.
best regards
Re: Tcontourseries
Posted: Wed Dec 02, 2015 12:06 pm
I understand you are looking for the arrays of Points into the Segments into the Levels. Here you have a simple example printing all the X and Y values for each Points array in each Segment in each Level:
var Series1: TContourSeries;
var i, j, m: Integer;
    lvl: TContourLevel;
    seg: TLevelSegment;
  Chart1.View3D:=false;
  Series1:=Chart1.AddSeries(TContourSeries) as TContourSeries;
  Series1.FillSampleValues();
  Series1.Marks.Visible:=true;
  Chart1.Draw;
  Memo1.ScrollBars:=ssVertical;
  Memo1.Lines.Clear;
    lvl:=Series1.Levels.Items[i];
    Memo1.Lines.Add('Level: ' + IntToStr(i) + ', UpToValue: ' + FormatFloat('#,##0.###', lvl.UpToValue));
    for j:=0 to length(lvl.Segments)-1 do
      seg:=lvl.Segments[j];
      Memo1.Lines.Add('Segment: ' + IntToStr(j));
      for m:=0 to length(seg.Points)-1 do
        Memo1.Lines.Add('Point[' + IntToStr(m) + ']: (' + FormatFloat('#,##0.###', seg.Points[m].X) + ',' + FormatFloat('#,##0.###', seg.Points[m].Y) + ')');
      Memo1.Lines.Add('');
Re: Tcontourseries
Posted: Tue Dec 08, 2015 1:40 pm
by 16476632
Tank you very much! It is exactelly le answer I was loocking for.
