Question about RotateLabel
Posted: Fri Oct 09, 2015 6:55 pm
by 16570614
I am using TChart 2015.15.150420 32 bit and I am using Canvas3D.RotateLabel to draw a rotated text. The last parameter of the RotateLabel procedure is AllowHTML which I set to true. What HTML should I use to present a subscript character?
Re: Question about RotateLabel
Posted: Tue Oct 13, 2015 3:24 pm
<SUB>SubScript Text Here</SUB>
Posted: Tue Oct 13, 2015 4:23 pm
by 16570614
Hello Yeray,
I tried that but unfortunately it does not work, my actual code is:
procedure TMainForm.Chart11AfterDraw(Sender: TObject);
  TChart(Sender).Canvas.RotateLabel(X, Y, '<SUB>SubScript Text Here</SUB>', 45 , true);
Am I missing something?
Posted: Wed Oct 14, 2015 9:53 am
by narcis
Hello johnnix,
It works for me compared with non-subscript text, for example:
var X, Y: Integer;
  TChart(Sender).Canvas.Font.Size:=15;
  X:=100;
  Y:=X;
  TChart(Sender).Canvas.RotateLabel(X, Y, 'Normal Text <SUB>SubScript Text Here</SUB>', 45 , true);
Posted: Wed Oct 14, 2015 5:24 pm
by 16570614
Hello Narcis,
Could it be my version? I just tried a plot Title in HTML and that does not work also (double clicked a plot -> Titles -> Options -> Format HTML) :(
Posted: Thu Oct 15, 2015 7:59 am
I've just checked it works in v2015.15 for me here:
The position of the Subscript text isn't correct with oblique angles, but the text and the font size look correct.
Note I've added this to output the build version string on the chart title:
uses TeeConst;
Posted: Thu Oct 15, 2015 6:37 pm
by 10046032
... does not work for me :( What could be the issue?
Posted: Fri Oct 16, 2015 11:47 am
What IDE are you using?
Posted: Fri Oct 16, 2015 12:19 pm
by 16570614
Delphi XE7 Version 21.0.17707.5020
Posted: Fri Oct 16, 2015 3:33 pm
Looking again at your screenshot I've seen what is making the difference here: RotateLabel method doesn't support HTML5 tags in GDI Canvas.
http://bugs.teechart.net/show_bug.cgi?id=1343
In the meanwhile you can use GDIPlus instead of GDI.
Posted: Sun Oct 18, 2015 7:43 am
by 16570614
Understood :)
Posted: Wed Feb 15, 2017 1:20 pm
Reviewing if it's worth implementing the support for the HTML in RotateLabel, doesn't GDIPlus satisfy your needs?
Posted: Wed Mar 01, 2017 8:40 am
#1343 has been closed as "Won't Fix". We recommend moving to GDIPlus.
