x-axis title offset
Posted: Mon May 04, 2015 9:45 am
by 16573450
apologise if this question was already addressed, but how can I set an offset to an axis title? How can I do that?
thanks in advance
Re: x-axis title offset
Posted: Mon May 04, 2015 2:38 pm
I'm afraid the automatic alignment doesn't allow offsets. Instead, you could use a custom position:
  Chart1.Title.CustomPosition:=true;
  Chart1.Title.Left:=100;
  Chart1.Title.Top:=50;
Posted: Mon May 04, 2015 4:36 pm
by 16573450
thanks for the prompt reply, but my question was about the position of the axis label, not the chart title.
I need to have:
chart1.BottomAxis.Title.Caption := 'bla';
I want to change the position of this label. How can I do this?
thanks, nabil
Posted: Tue May 05, 2015 9:20 am
Hi Nabil,
cssesuc wrote:thanks for the prompt reply, but my question was about the position of the axis label, not the chart title.
Oups, I misread that.
cssesuc wrote:I need to have:
I'm afraid that's not possible. Instead, you should use an annotation tool and set its position manually.
Posted: Wed May 06, 2015 9:20 am
by 16573450
thanks for the reply. Sorry, I am not familiar with the TeeChart library yet.
You write: "you should use an annotation tool and set its position manually."
could you provide me with some lines of code on how to implement that for the bottom axis?
thanks for your valuable help
Posted: Wed May 06, 2015 10:01 am
Here you are:
uses Series, TeeTools;
var annot1: TAnnotationTool;
  Chart1.AddSeries(TBarSeries).FillSampleValues;
  annot1:=Chart1.Tools.Add(TAnnotationTool) as TAnnotationTool;
  with annot1 do
    Text:='This is a bottom axis title with offset';
    Shape.Transparent:=true;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
var xOffset, tmpWidth, tmpHeight: Integer;
  xOffset:=10;
  annot1.Shape.CustomPosition:=true;
  tmpWidth:=annot1.Width;
  tmpHeight:=annot1.Height;
  Chart1.Canvas.AssignFont(annot1.Shape.Font);
  if tmpWidth=0 then
    tmpWidth:=Chart1.Canvas.TextWidth(annot1.Text);
  if tmpHeight=0 then
    tmpHeight:=Chart1.Canvas.TextHeight(annot1.Text);
  annot1.Left:=Chart1.Axes.Bottom.IStartPos + Chart1.Axes.Bottom.IAxisSize div 2 - tmpWidth div 2 + xOffset;
  annot1.Top:=Chart1.Height - tmpHeight - 10;
Posted: Wed May 06, 2015 12:43 pm
by 16573450
Hi could you send me the entire project to check, because it simply fails. I am wondering whether it comes from some misconfiguration at my side.
thanks
Posted: Wed May 06, 2015 1:04 pm
Here it is:
testAnnotation.zip
(1.79 KiB) Downloaded 825 times
At designtime I only dropped into the form, aligned the chart to alClient and assigned FormCreate and Chart1BeforeDrawSeries events.
