Problem with Smoothing function
johnnix
Post by johnnix » Fri Mar 06, 2015 5:32 pm
I am using the latest 2015 version and it looks like the smoothing function does not perform any more when working with TPoint series? Attached is a simple example, if I click the button I get a strange straight line only.
Sample.zip
(2.6 KiB) Downloaded 1044 times
Re: Problem with Smoothing function
Post by Yeray » Mon Mar 09, 2015 10:02 am
Could you please tell us with what TeeChart version this sample behaves different?
johnnix
Post by johnnix » Mon Mar 09, 2015 10:45 am
I am using the latest TeeChart 2015.14.150120. If I use another series type like Line series it works ok.
Post by Yeray » Tue Mar 10, 2015 3:45 pm
Try this:
type
  TSeriesAccess=class(TChartSeries);
TSeriesAccess(Chart6[1]).SetHorizontal;
 Chart6[1].FillSampleValues(20);
 teefunction1.ReCalculate;
johnnix
Post by johnnix » Tue Mar 10, 2015 5:09 pm
Hello Yeray,
Thank you very much for looking into this. I implemented your suggestion in my app and it works ok but I need to ask, is this a temporary fix or this is by design the way point series should be used with smoothing function?
Post by Narcís » Wed Mar 11, 2015 7:57 am
Hello johnnix,
This is by design. TPointSeries is a vertical series while, in your example, you are using a THorizLineSeries, which is a horizontal series. Given that, you need to make the point series to be horizontal so it can work with an horizontal line series.
johnnix
Post by johnnix » Wed Mar 11, 2015 12:53 pm
Hello Narcis,
Thank you very much for the clarification and quick answers.
