Issue with TeeCreatMetafile
johnnix
Post by johnnix » Sat Jun 28, 2014 7:22 pm
I am using the latest 2014 TeeChart under XE6 and Windows 8.1 Attached you may find a sample application that creates a metafile and assigns it in a TImage. You can see that at the right and bottom of the created metafile appears something like a border.
Unit1.zip
(56.72 KiB) Downloaded 602 times
Re: Issue with TeeCreatMetafile
Post by Yeray » Mon Jun 30, 2014 11:51 am
This sounds to be the same here:
http://www.teechart.net/support/viewtop ... =3&t=14851
In your case, these could be a workaround for you:
var m: tmetafile;
    oldColor: TColor;
  oldColor:=Self.Color;
  Self.Color:=clWhite;
  m := Chart5.TeeCreateMetafile(false,
    Rect(0, 0, Round(Image1.Width), Round(Image1.Height)));
  Image1.Picture.Assign(m);
  m.Free;
  Self.Color:=oldColor;
johnnix
Post by johnnix » Mon Jun 30, 2014 4:59 pm
Hello Yeray,
Thank you for your reply, indeed the code you mentioned fixes the issue but before I add so many lines to my projects do you have an estimate if this will be fixed shortly?
Post by Yeray » Tue Jul 01, 2014 9:57 am
johnnix wrote:Thank you for your reply, indeed the code you mentioned fixes the issue but before I add so many lines to my projects do you have an estimate if this will be fixed shortly?
I've incremented the issue priority but I'm afraid I can't tell you a date for this to be fixed.
I see you've added your mail to the ticket so you can be notified when it will be closed.
