TeeCreateBitmap with transparent color
mivtee
Post by mivtee » Mon Jun 23, 2014 2:07 pm
with TeeCreateBitmap, how to create a bitmap with transparent background?
Re: TeeCreateBitmap with transparent color
Post by Narcís » Mon Jun 23, 2014 2:45 pm
You can do something similar to the example Yeray posted here. That is also being explained in this article I wrote. Does this help you achieve what you expected?
mivtee
Post by mivtee » Mon Jun 23, 2014 3:24 pm
I tried Chart1.draw, it works in the VCL but under Intraweb i have an exception:
'Le contrôle 'Control1' n'a pas de fenêtre parente'
I don't have this problem with TeeCreateBitmap, but I don't have the transparent background...
mivtee
Post by mivtee » Wed Jun 25, 2014 6:39 am
would it possible to have background transparancy with TeeCreateBitmap?
If not, is there a problem with the function draw when we you use it in intraweb? Can it be solve?
mivtee
Post by mivtee » Wed Jun 25, 2014 10:36 am
The function Draw of the chart have problem only in GDI+.
So I have transparency now but only if I put this: Chart1.Canvas:=TTeeCanvas3D.Create.
Post by Yeray » Thu Jun 26, 2014 8:15 am
mivtee wrote:I tried Chart1.draw, it works in the VCL but under Intraweb i have an exception:
I'm not sure about what TeeChart version are you using.
Note the "Control has no parent window" error in TeeChart for Intraweb and similars was fixed with the update for TeeChart Lite for RAD Studio XE5, as you can read here.
Are you using a TeeChart version published later to the 1st Feb 2014?
mivtee
Post by mivtee » Thu Jun 26, 2014 10:04 am
I use the last release 2014.11.140512, and I'm waiting for next release that correct some other problems.
Post by Yeray » Thu Jun 26, 2014 1:17 pm
And have you tried with:
aChart.BufferedDisplay:=False;
As suggested here?
