Tools / TExtraLegendTool broken in TeeChart pro v2014
Posted: Tue Apr 29, 2014 10:19 am
by 16565544
I've been unable to use the TExtraLegendTool recently, regardless of the legend options, the extra legend does not show anywhere on the chart.
After a while, i've realised that the TeeChart Pro demo 2014 exhibits the same behavior.
I might be mistaken, but it looks like a regression no ?
See attached screenshots.
Don't hesitate to contact me for further information,
(Note : i've source code access, if the fix is simple enough, i'll be really interested in a patch to fix this)
Thanks in advance for your help,
Re: Tools / TExtraLegendTool broken in TeeChart pro v2014
Posted: Tue Apr 29, 2014 11:40 am
by 16565544
I forget to mention the version i'm using : TeeChart pro v2014.10.140220.
Thanks in advance,
Posted: Tue Apr 29, 2014 12:26 pm
by 16565544
- current behavior
- multiple_legend_2014.jpg (273.08 KiB) Viewed 22295 times
- expected behavior
- multiple_legend_2010.jpg (233.92 KiB) Viewed 22282 times
On a side (and probably unrelated note), there seems to be a slight glitch in the legend-canvas drawing stuff
in the latest demo of Multiple Legend in the demo of Tee9New_win32.exe
(GDI+ selection/deselection does not impact the resulting output)
Bottom line is, getting multiple legend is a tricky business in version 2014.10.140220 (VCL)
Posted: Wed Apr 30, 2014 10:19 am
dsn wrote:I've been unable to use the TExtraLegendTool recently, regardless of the legend options, the extra legend does not show anywhere on the chart.
I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=755
Feel free to add your mail to the ticket CC list to be automatically notified when an update on it arrives.
dsn wrote:On a side (and probably unrelated note), there seems to be a slight glitch in the legend-canvas drawing stuff
I've also reproduced this and added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=756
dsn wrote:Bottom line is, getting multiple legend is a tricky business in version 2014.10.140220 (VCL)
As you'll see, I've found a possible
fix for the second. Feel free to implement the change in your sources.
Posted: Wed Apr 29, 2015 2:42 pm
by 16558670
This hasn't been fixed already?
Please note that this issue is exactly 1 year old, which is unacceptable in my opinion.
Posted: Thu May 07, 2015 2:34 pm
Hello Bert,
Excuse us for the delayed reply here.
We closed both tickets as "fixed" a week ago:
Since you own the sources, you can apply the changes to them and recompile them.
The change is quite simple actually:
- At Chart.pas, move CalcRect from the
private section on TCustomChartLegend class to the
protected section.
- At TeeExtraLegendTool.pas, call TLegendAccess(Legend).CalcRect before Legend.DrawLegend:
procedure TExtraLegendTool.ChartEvent(AEvent: TChartToolEvent);
inherited;
if (AEvent=cteAfterDraw) then
if Assigned(ParentChart) and Assigned(Series) then
Legend.Series:=Series; // call getter
if Legend.Visible then
TLegendAccess(Legend).CalcRect;
Legend.DrawLegend;
Posted: Fri May 08, 2015 8:20 am
by 16558670
Hello Yeray,
The fix works fine, thanks.
I am still using version 2014.12.140923 and had to change the TCustomChartLegend class. This class has been renamed since then?
Bert
Posted: Fri May 08, 2015 3:13 pm
Hi Bert,
Bert B. wrote:I am still using version 2014.12.140923 and had to change the TCustomChartLegend class. This class has been renamed since then?
TCustomChartLegend class is defined in Chart.pas unit in the actual sources and also in v2014.12. I'm not sure to understand your doubt.
Posted: Mon May 11, 2015 6:37 am
by 16558670
Hello Yeray,
You wrote about a change in the TCustomLegend class but I had to change the TCustomChartLegend class.
Bert
Posted: Mon May 11, 2015 7:51 am
Hi Bert,
I'm sorry, I missed the "Chart" part in the TCustomChartLegend.
I'll edit the post above to correct it.
Posted: Mon Jun 29, 2015 3:00 pm
by 16473946
We do suffer from this issue, too. We need to create a Chart showing a CustomLegend which diesn't show. Unfortunately we do not have the sources.
So my question: when this issue will be fixed for public?
Thanks in advance!
Klaus
Posted: Tue Jun 30, 2015 8:17 am
Hi Klaus,
cvita wrote:when this issue will be fixed for public?
The next maintenance release should include these fixes. However, I'm afraid I can't tell you when the it will be published.
We'll prepare a test installer and we'll send you a mail with the link to it asap.
Posted: Tue Jun 30, 2015 8:38 am
Hi Klaus,
Yeray wrote:We'll prepare a test installer and we'll send you a mail with the link to it asap.
Could you please tell us what IDE are you interested in?
Posted: Tue Jun 30, 2015 9:37 am
by 16473946
Hello Yeray!
It would be really great to have this fix ASAP. Thanks for the offer!
We use currently Delphi XE5.
Regards and thanks again,
Klaus
Posted: Tue Jun 30, 2015 10:39 am
Hi Klaus,
I've just sent it to the mail account you have registered in this forum.
