Losing Increment value
Blair
Post by Blair » Mon Mar 31, 2014 5:22 pm
I'm trying the following code.
procedure TForm1.btnBuildClick(Sender: TObject);
Var tmpSeries : TCircularGauge;
   tmpSeries := TCircularGauge.Create(Self);
   tmpSeries.Maximum  := 10;
   tmpSeries.Value    := 2.4;
    tmpSeries.ParentChart       := Chart1;
   Chart1.BottomAxis.Increment := 0.5       {<-------}
procedure TForm1.btnSaveClick(Sender: TObject);
 SaveChartToFile(TCustomChart(Chart1), 'Test.Tee', True, True);
procedure TForm1.btnLoadClick(Sender: TObject);
  LoadChartFromFile(TCustomChart(Chart1), 'Test.Tee');
Checking the .tee file everything gets saved. But when I try reloading the increment doesn't load properly.
Re: Losing Increment value
Post by Yeray » Tue Apr 01, 2014 8:28 am
Hello Blair,
I've checked it and I confirm it doesn't work well with TeeChart v2014.10. However, the gauges have been deeply redesigned so I've checked also with the actual sources we have here and it seem to work perfectly.
See the project attached, and the respective exe built with the actual sources:
testExportIncr.zip
(1.75 MiB) Downloaded 611 times
We expect to prepare new installers very soon.
Blair
Post by Blair » Tue Apr 01, 2014 2:10 pm
Any chance for a hotfix?
Post by Yeray » Wed Apr 02, 2014 8:23 am
Hi Blair,
We should publish new installers soon. This would be the fix.
