Error reading TColorLineTool.AxisID
Byron
Post by Byron » Thu Mar 27, 2014 9:23 pm
I have a project that uses a TDBChart. This works fine in the prior version, but in the current version I get an error when the form is created. The error, "Error reading TColorLineTool.AxisID", displays while the form is being created. I have attached a test project for your review. I've tried recreating the ColorLineTool and ColorBandTool, and I've tried assigning the Axis property programmatically, but none of these measures works.
Current TeeChart Version: TeeChart Pro v2014.10.140220 32bit VCL
IDE: Delphi XE5, Windows 7 64-bit
Prior TeeChart Version: TeeChart Pro v2012.07.121105 32bit VCL
IDE: Delphi XE, Windows 7 64-bit
TestChartProject.zip
Test project
(11.16 KiB) Downloaded 283 times
Re: Error reading TColorLineTool.AxisID
Post by Yeray » Fri Mar 28, 2014 4:34 pm
That's strange, I could load, see the form and even run the project you attached without problems in RAD Studio XE5 with TeeChart Pro v2014.14.
I'd suggest you to reinstall TeeChart; you could try just running TeeInstall.exe twice (one to uninstall and the second to reinstall) from the TeeChart installation folder.
I could also load the project in Delphi 7 also with TeeChart v2014.10. And I've seen the AxisID property has been defined since TeeChart v7 (and probably even before) for TTeeCustomToolAxis. So I don't think it should cause any compatibility issue.
Byron
Post by Byron » Fri Mar 28, 2014 8:41 pm
You were right. Something went wrong in my initial installation. In my case, I ran "TeeChart2014SourceCode.exe" and then ran "TeeRecompile.exe" (located in the Program Files folder). That solved my problem.
Post by Yeray » Mon Mar 31, 2014 7:14 am
Byron wrote:You were right. Something went wrong in my initial installation. In my case, I ran "TeeChart2014SourceCode.exe" and then ran "TeeRecompile.exe" (located in the Program Files folder). That solved my problem.
You are welcome. I'm glad to hear you found how to make it work.
