Trend example
Numinor
Trend example
Post by Numinor » Thu Mar 06, 2014 7:55 pm
I just purchased Pro so I could use trends in my graph. I need to configure it in design mode-
procedure TfrmPsrGraph.SetupGraph(const v1,v2,v3:shortstring);
  xBar3:TBarSeries;
  xTrend:TTrendFunction;
  m, b: Double;
  xTrend:=TTrendFunction.Create(self);
  xBar3:=TBarSeries.Create(chtPSR);
  xBar3.ParentChart:=chtPSR;
  xBar3.SetFunction(xTrend);
  xBar3.DataSource:=fPSRTable;
  xBar3.CheckDataSource;
  xTrend.CalculateTrend(m,b,xBar3,0,xBar3.Count);
  xBar3.YValues.ValueSource:=v3;
  xBar3.XValues.ValueSource:='psrdate';
  xBar3.XValues.DateTime:=true;
  xBar3.ShowInLegend:=false;
  xBar3.Marks.Visible:=false;
  xBar3.color:=clBlue;
  xBar3.RefreshSeries;
  xBar3.Title:='s3';
  xBar3.ShowInLegend:=true;
  chtPSR.BottomAxis.ExactDateTime:=true;
  chtPSR.BottomAxis.DateTimeFormat:='m/d';
  chtPSR.BottomAxis.Increment:= DateTimeStep[dtOneDay];
Obviously this doesnt draw a trend line. I see the bar graph but that's all. Any help will be appreciated.
Re: Trend example
Post by Yeray » Fri Mar 07, 2014 9:34 am
Hello and welcome to the forums,
Note the functions need a series linked to them to be represented. In your case, a trend function is usually represented with a line series. Ie:
uses Series, CurvFitt;
  xBar:TBarSeries;
  xLine: TLineSeries;
  m, b: Double;
  xTrend:=TTrendFunction.Create(Self);
  xBar:=TBarSeries.Create(Self);
  xBar.ParentChart:=Chart1;
  //xBar.SetFunction(xTrend);
  xBar.FillSampleValues;
  //xBar.DataSource:=fPSRTable;
  //xBar.CheckDataSource;
  xTrend.CalculateTrend(m,b,xBar,0,xBar.Count);
  //xBar.YValues.ValueSource:=v3;
  //xBar.XValues.ValueSource:='psrdate';
  xBar.XValues.DateTime:=true;
  xBar.ShowInLegend:=false;
  xBar.Marks.Visible:=false;
  xBar.color:=clBlue;
  xBar.RefreshSeries;
  xBar.Title:='s3';
  xBar.ShowInLegend:=true;
  Chart1.BottomAxis.ExactDateTime:=true;
  Chart1.BottomAxis.DateTimeFormat:='m/d';
  Chart1.BottomAxis.Increment:= DateTimeStep[dtOneDay];
  xLine:=TLineSeries.Create(Self);
  xLine.ParentChart:=Chart1;
  xLine.SetFunction(xTrend);
  xLine.DataSource:=xBar;
  //xTrend.Period:=2;  //note you can change the period
I'd suggest you to take a look at the tutorials and to the features demo, both shipped with the installation.
I've just replied a very similar question here
Numinor
Re: Trend example
Post by Numinor » Fri Mar 07, 2014 2:23 pm
Thank you! Seeing the code makes it all look obvious now. btw, I couldn't find any examples of how to do this in design mode. Everything I saw was adjusting properties in the editor. I rarely use the editor in my projects.
Re: Trend example
Post by Narcís » Tue Mar 11, 2014 2:51 pm
Hi Numinor,
Numinor wrote:I couldn't find any examples of how to do this in design mode.
You'll find some instructions in tutorial 7. Tutorials can be found at the program group created by binary package installers. If you still need some help don't hesitate to let us know.
