Compiled In XE5 all Tchart Plots are in black
WJEC
Post by WJEC » Tue Mar 04, 2014 12:16 am
Delphic XE5 Update 2
TChart v2014.10.140220 32Bit VCL
I have an application with a TChart component with several series on it. I compile under XE5 and run on a Windows 7 computer and I am able to change the Series display colors as required. If however I run the same exe on an XP computer the Series colors will not change, they stay black. I am unable to change the Series Colors.
Any help on the above would be appreciated.
Re: Compiled In XE5 all Tchart Plots are in black
Post by Yeray » Tue Mar 04, 2014 10:21 am
While we prepare a machine with XP, could you please check if this happens in a new simple example project with just some series in a new chart?
What type of series are you using? And what other properties do we have to set to reproduce the problem here?
It would be helpful if you could arrange a simple example project we can run as-is to reproduce the problem here.
