Memory leak in the Surface Series
- Newbie
I found a memory leak in the Surface series, will compile test1 program and after start will check memory by TaskManager
- test1.zip
- (48.37 KiB) Downloaded 782 times
With best regards
Vladimir
Vladimir
Re: Memory leak in the Surface Series
Hello Vladimir,
I think with GDI it works better than with GDI+, could you please confirm it?
Delphi testing application:
After confirming it, if you want you can add it to the bugzilla tracking system:
http://bugs.teechart.net/
uses Chart, TeeGDIPlus, TeCanvas, TeeSurfa;
var Chart1: TChart;
Series1: TSurfaceSeries;
Chart1:=TChart.Create(Self);
Chart1.Parent:=Self;
Chart1.Align:=alClient;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
Series1:=Chart1.AddSeries(TSurfaceSeries) as TSurfaceSeries;
Series1.FillSampleValues(128);
RadioGroup1Click(Self);
procedure TForm1.Timer1Timer(Sender: TObject);
var x, z: Integer;
for x:=0 to 127 do
for z:=0 to 127 do
Series1.Value[x,z]:=random(512);
procedure TForm1.RadioGroup1Click(Sender: TObject);
case RadioGroup1.ItemIndex of
0: if Chart1.Canvas is TTeeCanvas3D then
Chart1.Canvas:=TGDIPlusCanvas.Create;
1: if Chart1.Canvas is TGDIPlusCanvas then
Chart1.Canvas:=TTeeCanvas3D.Create;
- Newbie
Hi Yeray
I've just checked with the GDI rendering, the bug exists also with the same rate of the memory leak.
By the way, this bug exists only in the last version of the TeeChart, the previous works fine, for this reason I am using now the previous version of the TeeChart (from November 2013).
The TColorBand bug (my other report) also is absent in the previous version.
With best regards
Vladimir
Vladimir
Hi Vladimir,
Thanks for your feedback. I could reproduce the issue here and added it to the bug list (ID611). Please feel free to sign up at Steema Software's bugzilla platform to be able to get automatic issue update notifications.
It has just been fixed for the next maintenance release, see David Berneda's comment.anauta2014 wrote:The TColorBand bug (my other report) also is absent in the previous version.
