Problem with GDI+ Redering...
- Newbie
I've just upgraded to the latest version (Nov 19th) and I'm having some problems with the GDI+ rendering. Take a look here:
http://screencast.com/t/PwgsPpAoAj
Where am I going wrong?
My graphics card is an NVIDIA GeoForce GT 740M running on a HP Envy Laptop with Windows 8.1 64 bit.
I hope it's a quick fix!
Steve
Steve
Re: Problem with GDI+ Redering...
Hi Steve,
This is a pretty serious issue. We couldn't reproduce it here though. Is your chart color set to clNone (Chart1.Color :=clNone)? Also, we are going to make some changes to TeeGDIPlus.pas and send it to you to check if it makes any difference.
Hi Steve,
Or are you using Chart1.ParentColor:=True?Narcís wrote:Is your chart color set to clNone (Chart1.Color :=clNone)?
We have also added the line below at the GDI+ canvas. This is a global variable set to False by default. Now it will force the background being erased in GDI+. I'll send you an email with TeeGDIPlus.pas with the mentioned modification. Can you please test if it solve the problem at your end? If it persists, it would be helpful if you could debug it to find the cause.Narcís wrote:Also, we are going to make some changes to TeeGDIPlus.pas and send it to you to check if it makes any difference.
TeeEraseBack:=True;
- Newbie
Hi Narcis,
The problem still persists after the patch. ParentColor was initially set to "true" and Color was "clWindow".
Here's a video which take you through the problem:
http://www.youtube.com/watch?v=zJ5Opq1M5gM
I hope it can be fixed.
Steve
Steve
Hi Steve,
Thanks for your feedback. I can not see the video because it's private.
- Newbie
Oops - sorry!
Try again and you should be able to see it,
Steve
Steve
Hi Steve,
Excellent, thanks. We could see your video and just sent you a fix proposal at TeeProcs. pas. Can you please check if it solves the issue for you?
- Newbie
Thanks Narcis,
Unfortunately after copying the new file you sent, it won't compile.
Here's the log (also attached).
Steve
Steve
TeeChart Pro
Compilation started: 11/21/2013 8:34:37 AM
Win32 v18 (Delphi XE4 and C++Builder XE4 Update 1) ERROR
Tee918
Embarcadero Delphi for Win32 compiler version 25.0
Copyright (c) 1983,2013 Embarcadero Technologies, Inc.
85192 lines, 0.44 seconds, 938748 bytes code, 4520 bytes data.
TeeUI918
78411 lines, 0.47 seconds, 609568 bytes code, 1364 bytes data.
TeeDB918
8405 lines, 0.16 seconds, 88064 bytes code, 288 bytes data.
TeePro918
Cannot recompile Delphi package: TeePro918.dpk
Error: E2161 Error: RLINK32: Unsupported 16bit resource in file "C:\Delphi XE4\Steema\TeeChart Pro 2013 Full Source Code\Sources\VCL\VCLTee.TeeDoubleHorizBarEditor.dfm"
EXCEPTION:
Compilation aborted.
Hi Steve,
It might be that the error causing .dfm got corrupted for some unknown reason. Maybe an uncomplete TeeRecompile process. Could you please send us the C:\Delphi XE4\Steema\TeeChart Pro 2013 Full Source Code\Sources\VCL\VCLTee.TeeDoubleHorizBarEditor.dfm file so that we can investigate what went wrong?
- Newbie
Hi Narcis,
I've attached it.
Best regards,
Steve
I've attached it.
Best regards,
Steve
- VCLTee.TeeDoubleHorizBarEditor.zip
- (633 Bytes) Downloaded 984 times
Hi Steve,
Thanks, that looks like a XML file that has nothing to do with the editor we would have expected. This might have been corrupted. You could try installing sources again and replacing relevant units with the files I sent.
- Newbie
Hi Narcvis,
That makes sense as I'm facing some hard disk and corrupt "cryptnet.dll" issues. I thought they were unrelated to this issue, and they may well be. I'm going to restore to factory setting today and over the weekend. I'll keep you posted.
Best regards,
Steve
Best regards,
Steve
- Newbie
Hi Narcis,
Everything works with the latest patch!!
Many thanks,
Steve
Many thanks,
Steve
Hi Steve,
You're very welcome. We are glad to hear that.
We have the same problem. How can we get the latest patch ?
