Page 1 of 2
XE5 ?
Posted: Mon Sep 16, 2013 1:37 am
by 9236183
Is there an estimate of when an XE5 release will be available ?
Re: XE5 ?
Posted: Mon Sep 16, 2013 7:07 am
by narcis
Hello bdw,
Not a fixed date but we expect it won't be long. For now we have a beta which supports it. You can find it here.
Re: XE5 ?
Posted: Mon Sep 16, 2013 12:19 pm
by 16565588
I've compiled and tested this beta for XE5? it seems works .
But fortunately I found the reason concerned old CBuilderXE4 bug (absence of *GDI*.hpp files)
I have two copies of the BuilderXE5, one was installed without Standard TeeChart, second with standard TeeChart.
for the first one this old error exists, for the second one TeeChart works fine.
After updating of the first CBuilder XE5 with the Standard TeeChart, the reinstalling of the TeeChartPro Beta removed the problem, and *GDI*.hpp files were installed.
Re: XE5 ?
Posted: Thu Sep 19, 2013 9:56 am
by 16564788
Hi - one issue I've found with the Beta is that a TListView's performance degrades very badly as soon as I add a chart to the same tab. ListViews on other tabs seem to behave fine.
Richard
Re: XE5 ?
Posted: Thu Sep 19, 2013 9:57 am
by 16564788
Sorry, should have said I have tested on iPad and Nexus 7 (2012) and same performance issue on both. As soon as I delete the chart it behaves fine.
The issue only seems to appear when a series has been added - a TChart with no series has no impact.
Re: XE5 ?
Posted: Thu Sep 19, 2013 10:28 am
by narcis
Hi anauta2014 and RichardS,
Could you please post the issues you come across with the beta to this beta specific forum?
Re: XE5 ?
Posted: Mon Sep 23, 2013 2:04 pm
by 16564788
I have requested a password for the beta forum but not received a reply.
Having a TChart on a form also seems to impact on the smooth transition effect available when changing tabs - it becomes very jerky.
Re: XE5 ?
Posted: Mon Sep 23, 2013 2:21 pm
by narcis
Hi RichardS,
I just sent you an email with the password.
Re: XE5 ?
Posted: Fri Sep 27, 2013 5:46 pm
by 16566632
We have the 2013 version. We bought it two months ago. This version is compatible with XE5? we need to aquire another version?
Re: XE5 ?
Posted: Mon Sep 30, 2013 6:42 am
by narcis
Hi QUERY,
Yes, there's a beta version with XE5 support here. A full maintenance release for v2012/2013 customers will follow up soon. Stay tuned!
Re: XE5 ?
Posted: Fri Oct 04, 2013 5:40 pm
by 16467403
We just purchased one source & 2 binary licenses for v2013, as we were understanding that XE4 products could be installed in XE5, but the installer won't allow us to do this. Can you please provide us with an XE5 version and the proper access codes?
Re: XE5 ?
Posted: Mon Oct 07, 2013 7:14 am
I'm afraid the only version supporting XE5 at the moment is the SourceCode beta NarcĂ­s mentioned earlier.
We are working on the Pro and Standard versions to publish the respective binary installers (and a the final SourceCode version) as soon as possible. In the meanwhile, please use the beta.
Re: XE5 ?
Posted: Sun Oct 13, 2013 5:58 am
by 9236183
Did you have an estimate of release date ?
Re: XE5 ?
Posted: Mon Oct 14, 2013 7:18 am
We are working to finish and publish it as soon as possible but I'm afraid I can't tell you a date for it.
Re: XE5 ?
Posted: Sun Nov 03, 2013 7:23 pm
by 16566186
Still no estimated time for release?
Thanks in advance,
Omar Zelaya
