XE5 ?
bdw
XE5 ?
Post by bdw » Mon Sep 16, 2013 1:37 am
Is there an estimate of when an XE5 release will be available ?
Re: XE5 ?
Post by Narcís » Mon Sep 16, 2013 7:07 am
Hello bdw,
Not a fixed date but we expect it won't be long. For now we have a beta which supports it. You can find it here.
anauta2014
Re: XE5 ?
Post by anauta2014 » Mon Sep 16, 2013 12:19 pm
I've compiled and tested this beta for XE5? it seems works .
But fortunately I found the reason concerned old CBuilderXE4 bug (absence of *GDI*.hpp files)
I have two copies of the BuilderXE5, one was installed without Standard TeeChart, second with standard TeeChart.
for the first one this old error exists, for the second one TeeChart works fine.
After updating of the first CBuilder XE5 with the Standard TeeChart, the reinstalling of the TeeChartPro Beta removed the problem, and *GDI*.hpp files were installed.
With best regards
Vladimir
RichardS
Re: XE5 ?
Post by RichardS » Thu Sep 19, 2013 9:56 am
Hi - one issue I've found with the Beta is that a TListView's performance degrades very badly as soon as I add a chart to the same tab. ListViews on other tabs seem to behave fine.
Richard
RichardS
Re: XE5 ?
Post by RichardS » Thu Sep 19, 2013 9:57 am
Sorry, should have said I have tested on iPad and Nexus 7 (2012) and same performance issue on both. As soon as I delete the chart it behaves fine.
The issue only seems to appear when a series has been added - a TChart with no series has no impact.
Re: XE5 ?
Post by Narcís » Thu Sep 19, 2013 10:28 am
Hi anauta2014 and RichardS,
Could you please post the issues you come across with the beta to this beta specific forum?
RichardS
Re: XE5 ?
Post by RichardS » Mon Sep 23, 2013 2:04 pm
I have requested a password for the beta forum but not received a reply.
Having a TChart on a form also seems to impact on the smooth transition effect available when changing tabs - it becomes very jerky.
Re: XE5 ?
Post by Narcís » Mon Sep 23, 2013 2:21 pm
Hi RichardS,
I just sent you an email with the password.
QUERY
Re: XE5 ?
Post by QUERY » Fri Sep 27, 2013 5:46 pm
We have the 2013 version. We bought it two months ago. This version is compatible with XE5? we need to aquire another version?
Re: XE5 ?
Post by Narcís » Mon Sep 30, 2013 6:42 am
Hi QUERY,
Yes, there's a beta version with XE5 support here. A full maintenance release for v2012/2013 customers will follow up soon. Stay tuned!
wellworld
Re: XE5 ?
Post by wellworld » Fri Oct 04, 2013 5:40 pm
We just purchased one source & 2 binary licenses for v2013, as we were understanding that XE4 products could be installed in XE5, but the installer won't allow us to do this. Can you please provide us with an XE5 version and the proper access codes?
Re: XE5 ?
Post by Yeray » Mon Oct 07, 2013 7:14 am
I'm afraid the only version supporting XE5 at the moment is the SourceCode beta Narcís mentioned earlier.
We are working on the Pro and Standard versions to publish the respective binary installers (and a the final SourceCode version) as soon as possible. In the meanwhile, please use the beta.
bdw
Re: XE5 ?
Post by bdw » Sun Oct 13, 2013 5:58 am
Did you have an estimate of release date ?
Re: XE5 ?
Post by Yeray » Mon Oct 14, 2013 7:18 am
We are working to finish and publish it as soon as possible but I'm afraid I can't tell you a date for it.
Omar Zelaya
Re: XE5 ?
Post by Omar Zelaya » Sun Nov 03, 2013 7:23 pm
Still no estimated time for release?
Thanks in advance,
Omar Zelaya
