Automatic Axis Incorrect With TeeShapes
Posted: Tue Aug 20, 2013 5:33 am
by 16566747
When using TeeShape and the XYStyle set to xysAxisOrigin. The value enter for the number of pixels can be interrupted as a minimum or maximum value for the axis. If X0 is 1200 Y0 is 37.87 X1 is 15 and Y1 is 15, then the minimum for the X-Axis (Bottom) is 15 and for the Left Axis is 15. While I really what the shape to be centered at 1200 and be 15 pixels wide. You are almost forced to use xysAxis
and set X0,Y0 and calculate the width and set these values to X1 and Y1
Mike DuPree
Re: Automatic Axis Incorrect With TeeShapes
Posted: Wed Aug 21, 2013 3:35 pm
With the code below:
uses TeeShape;
Chart1.View3D:=false;
with Chart1.AddSeries(TChartShape) as TChartShape do
XYStyle:=xysAxisOrigin;
X0:=1200;
Y0:=37.87;
X1:=15;
Y1:=15;
I get this:
- shape1.png (12.45 KiB) Viewed 2866 times
If I scroll the chart a bit to the down-left, I see the shape:
- shape2.png (12.42 KiB) Viewed 2865 times
So, as you say, the axes seem to be wrongly scaled.
You can centre the shape with this:
uses TeeShape;
var tmp: Double;
X0:=1200;
Y0:=37.87;
X1:=15;
Y1:=15;
Chart1.Draw;
with Chart1.Axes.Left do
tmp:=(Maximum-Minimum)/2;
SetMinMax(Minimum+tmp, Maximum+tmp);
with Chart1.Axes.Bottom do
- shape3.png (12.67 KiB) Viewed 2869 times
