Pyramid series - inverted axis
DCConcept
Post by DCConcept » Tue Jul 16, 2013 12:48 pm
we are using Teechart 2013 for Delphi (with full source code). There is a bug (look at picture below) in combination of Pyramid series and inverted axis. You can try it by yourself in TeeChartOffice.
Is there any other way, how can I create inverted pyramid? Or can you please send me a piece of code, which fixes this bug?
Thank you very much.
Michal
Re: Pyramid series - inverted axis
Post by Yeray » Thu Jul 18, 2013 8:05 am
Hi Michal,
You are right. I could reproduce it so I've added it to the defect list to be revised for future releases (TV52016648)
Thanks for reporting it.
DCConcept
Post by DCConcept » Tue Jul 23, 2013 7:23 am
Thank you for your answer Yeray. Unfortunately there are more drawing problems with pyramid eg. in 3D, empty blocks are sometimes drawn in pyramid, if high number of values is set (it depends on window size too) - see picture below. And if you focus on pyramid edges, it is not drawn very well too :-(
We had to disable 3D option for users, if pyramid serie is placed in chart.
On the other hand, other serie types works great, especially pies are perfect.
Best regards.
Michal
Post by Yeray » Tue Jul 23, 2013 11:52 am
Hi Michal,
Thanks for reporting it. I've added it to the ticket description so not only the case of the inverted axis will be reviewed.
