Example folder missing
Daniele Buttarelli
Post by Daniele Buttarelli » Fri Jul 05, 2013 3:45 pm
I have installed TeeChart 2013 to Delphi XE2 (Upd4 +Hotfix1) in a custom folder ( not program files \Steema Software ... but \bds\components\steema\teechart pro ).
I don't find Examples\Features folder.
Thanks a lot
Re: Example folder missing
Post by Yeray » Tue Jul 09, 2013 8:11 am
Hi Alex,
I see you own a source code license. Note we use to recommend source code customers to install the binary version before the source code version because only the first one comes with the examples and documentation.
Find the binary version at the same page where you downloaded the source code version.
http://www.steema.com/clientaccess
After downloading and installing the binary version that matches your environment, run TeeRecompile again to rebuild & reinstall the source code version.
