Installation XE2 Scourcecode manual
arnof
Post by arnof » Tue Jun 18, 2013 10:42 am
the installation manual ends with delphi 2006 :evil:
i need installation with sourcecode, (i have change the DB Unit from delphi), pease wirte a manual to install the standardversion!
Re: Installation XE2 Scourcecode manual
Post by Yeray » Tue Jun 18, 2013 11:19 am
arnof wrote:the installation manual ends with delphi 2006 :evil:
Could you please specify what exact file are you looking at so we can check it?
arnof wrote:i need installation with sourcecode, (i have change the DB Unit from delphi), pease wirte a manual to install the standardversion!
The source code version comes with TeeRecompile tool that is the recommended way to build and install TeeChart sources.
Also note the examples and the documentation are only shipped with the binary version. That's why we use to recommend to install the binary version prior to the source code version.
arnof
Post by arnof » Tue Jun 18, 2013 11:49 am
Thank You,
i have found this before you ansering.
in the install.txt don't stand this (see Attachment) :idea:
Install.zip
(1.48 KiB) Downloaded 336 times
Post by Yeray » Tue Jun 18, 2013 1:43 pm
We have plans to modernize the instructions shipped with the installers in general (TV52015784).
