Sub chart order
Richard
Sub chart order
Post by Richard » Mon Jun 10, 2013 3:50 pm
I have a 5 by 5 grid of subcharts.
I would like to have it zoom one of the charts to full size if the mouse is held down over it - I have achieved this - but the charts do not have any way of re-ordering them, so if I Click on the first chat I made, most of it is hidden behind the other charts. If I click on the last one it woks fine - can I reorder the charts so that this will work - I want to avoid destroying all the charts if I can as I was hoping to get a nice zoom in feel with the clicked on chart getting bigger with the other small charts behind them!
Thanks for any help
Richard
Re: Sub chart order
Post by Yeray » Wed Jun 12, 2013 2:46 pm
Hi Richard,
Here is how you could swap two charts in a same TSubChartTool:
procedure TForm1.SwapChart(Index1, Index2: Integer);
var tmp : TSubChart;
  tmp:=ChartTool1.Charts[Index2];
  ChartTool1.Charts[Index1].Index:=Index2;
  tmp.Index:=Index1;
  Chart1.Draw;
Then you can use the Chart OnMouseDown event to check what SubChart has been clicked, and then you could swap the chart directly with the chart with index 0, or swap it with all the charts up to the index 0.
Here you have a starting point:
procedure TForm1.Chart1Click(Sender: TObject);
  if ChartTool1.Charts[0].Clicked(myMouseDown.X, myMouseDown.Y) then
    SwapChart(0,1);
  myMouseDown.X:=X;
  myMouseDown.Y:=Y;
Richard
Re: Sub chart order
Post by Richard » Fri Jun 14, 2013 8:53 am
Thanks for the heads up - it was the index value I was missing
