Synchronizing charts and the UndoZoom event
Metman
Post by Metman » Wed May 22, 2013 4:32 pm
I have 3 charts on my form and as they all have the same range of xvalues I have synchronized them as regards zooming and scrolling. This works fine all except for OnUndoZoom event. Obviously when I reset the zoom for Chart1 I want to call the UndoZoom for the other two charts which I do, but of course doing this fires their UndoZoom event which then calls Chart1's UndoZoom event in a recursive loop. There must be an easy way round this can you help?
Bruce.
Re: Synchronizing charts and the UndoZoom event
Post by Yeray » Thu May 23, 2013 10:18 am
Hi Bruce,
I'd suggest you to use flags to control this. Here you have an example:
uses Series;
var zoom1, zoom2: boolean;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.AddSeries(TPointSeries).FillSampleValues;
  Chart2.View3D:=false;
  Chart2.AddSeries(TPointSeries).DataSource:=Chart1[0];
  zoom1:=true;
  zoom2:=true;
  if zoom1 then
    zoom1:=false;
    with Chart1.Zoom do
      Chart2.ZoomRect(Rect(X0, Y0, X1, Y1));
    zoom1:=true;
procedure TForm1.Chart2Zoom(Sender: TObject);
  if zoom2 then
    zoom2:=false;
    with Chart2.Zoom do
      Chart1.ZoomRect(Rect(X0, Y0, X1, Y1));
    zoom2:=true;
  if zoom1 then
    zoom1:=false;
    Chart2.UndoZoom;
    zoom1:=true;
procedure TForm1.Chart2UndoZoom(Sender: TObject);
  if zoom2 then
    zoom2:=false;
    Chart1.UndoZoom;
    zoom2:=true;
Metman
Post by Metman » Thu May 23, 2013 12:39 pm
Thanks once again Yeray!
Post by Yeray » Thu May 23, 2013 2:50 pm
You're welcome, Bruce
