customize X-Axis time axis
bdw
Post by bdw » Fri May 10, 2013 3:41 am
We have a x-axis set to TDateTime which we set the BottomAxis->DateTimeFormat to "hh:nn" when showing less that 24 hours worth of data.
Is it possible to display at the day change over (i.e. 00:00 label) a different DateTimeFormat rather than hh:nn let say "ddd" or day + month ?
Re: customize X-Axis time axis
Post by Yeray » Fri May 10, 2013 9:18 am
You could use the OnGetAxisLabel. However, once you are in this event, you don't know the value for the current label. You already have the formatted label.
So you could set a DateTimeFormat that allows you to identify both the "ddd" (or the "dd/mm") and the "hh:nn". Here you have an example:
uses Series, DateUtils, StrUtils;
var i: Integer;
  Chart1.View3D:=false;
  with Chart1.AddSeries(TPointSeries) as TPointSeries do
    XValues.DateTime:=true;
    for i:=0 to 60 do
      AddXY(IncHour(Today, i), i);
  Chart1.Axes.Bottom.DateTimeFormat:='dd/mm hh:nn';
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
var p: Integer;
  if Sender = Chart1.Axes.Bottom then
    p:=AnsiPos(' ', LabelText);
    if AnsiEndsStr('00:00', LabelText) then
      LabelText:=Trim(AnsiLeftStr(LabelText, p))
      LabelText:=Trim(AnsiRightStr(LabelText, p));
