Is it possible to define a legend as a grid of Rows and Cols
Posted: Mon Mar 18, 2013 10:40 am
by 16464672
I am using the latest version of TeeChart Pro 2012 VCL on Delphi XE3.
Is it possible to define a legend as a grid of Rows and Cols. The text is too great and so I have to use a small font which is hard to read. Additionally if the application is resized the legend layout is lost and sprawls poorly across several lines (see images attached)
I was hoping to be able to define row and column headers and just have the appropriate coloured checkbox within; is this possible?
Many thanks in advance
Rob
Re: Is it possible to define a legend as a grid of Rows and Cols
Posted: Mon Mar 18, 2013 12:20 pm
by narcis
Hi Rob,
I'm not sure about what you mean with this:
Anyway, I'd recommend you to look at the custom legend tool demoed at the
What's New?\Welcome!\New Chart Tools\Custom Legend example in the features demo, available at TeeChart's program group or the TChartGrid component at
All Features\Welcome\Components\Chart Grid in the same demo.
If this doesn't fit your needs please give us more detailed information about what you are trying to achieve.
Posted: Mon Mar 18, 2013 2:47 pm
by 16464672
Hi Narcis,
I was hoping to achieve something akin to this
Posted: Tue Mar 19, 2013 10:55 am
by 16464672
As can be seen in the very first image, the legend loses its neat layout with all associated legends no longer in a straight vertical line down (effectively a column), which is represented in the second image.
However there is a lot of repeated text, and I wondered if it was possible to combine a consistent fixed number of rows and columns with the checkbox to switch on graphed datasets.
Please advise if this is possible.
Many thanks
Rob
Posted: Wed Mar 20, 2013 5:01 pm
Hi Rob,
Have you tried using the TCustomLegendTool as NarcĂs indicated?
I've made a quite complete example:
private
{ Private declarations }
procedure DrawCustomLegend();
procedure StringGrid1DrawCell(Sender: TObject; ACol, ARow: Integer;
Rect: TRect; State: TGridDrawState);
procedure ClickTool(Sender:TAnnotationTool; Button:TMouseButton; Shift: TShiftState; X, Y: Integer);
var
CustomLegendTool : TCustomLegendTool;
jobs : Array[0..4] of string = ('Builders', 'Electricians', 'Gardeners', 'Mechanical', 'Painters');
days : Array[0..3] of string = ('Within 1 Day', 'Within 3 Day', 'Within 7 Day', 'More than 7 Days');
colors: Array[0..4] of TColor;
var
i, j, d: Integer;
colors[0]:=rgb(226, 108, 10);
colors[1]:=rgb(49, 133, 157);
colors[2]:=rgb(118, 147, 57);
colors[3]:=rgb(149, 54, 52);
colors[4]:=rgb(128, 128, 128);
CustomLegendTool := TCustomLegendTool.Create(Chart1);
DrawCustomLegend();
for j:=0 to length(jobs)-1 do
for d:=0 to length(days)-1 do
Color:=ApplyBright(colors[j], 80-(d*20));
XValues.DateTime:=true;
BarStyle := bsBevel;
Active:=j=1;
for i:=0 to 3 do
AddXY(IncMonth(MonthOf(Today), i) , 30 + random*130)
CustomLegendTool.Height := 120;
with Chart1 do
Legend.Visible:=false;
Title.Visible:=false;
Axes.Bottom.DateTimeFormat:='MMMM';
Axes.Bottom.LabelStyle:=talPointValue;
MarginUnits:=muPixels;
MarginTop:=CustomLegendTool.Height + 20;
Chart1.Draw;
CustomLegendTool.Left := (Chart1.Width div 2) - (CustomLegendTool.Width div 2);
procedure TForm1.DrawCustomLegend();
var i: Integer;
with CustomLegendTool do
ParentChart := Chart1;
AllowDrag:=false;
AllowResize:=false;
with Shape do
RoundSize := 15;
Pen.Width:= 2;
Font.Style := [fsItalic];
ShapeStyle:=fosRectangle;
Grid.OnDrawCell:=StringGrid1DrawCell;
OnClick:=ClickTool;
with Grid do
ColCount := length(jobs)+1;
RowCount := length(days)+1;
for i:=0 to RowCount-1 do
RowHeights[i] := 20;
ColWidths[0] := 120;
for i:=1 to ColCount-1 do
ColWidths[i] := 80;
Height := 105;
Width := 526;
procedure TForm1.StringGrid1DrawCell(Sender: TObject; ACol, ARow: Integer;
var
seriesIndex: Integer;
if (ACol = 0) then
if (ARow > 0) then
with CustomLegendTool.Grid.Canvas.Font do
CustomLegendTool.Grid.Canvas.TextRect(Rect, Rect.Left+60, Rect.Top+1, days[ARow-1]);
end
if (ARow = 0) then
CustomLegendTool.Grid.Canvas.TextRect(Rect, Rect.Left+35, Rect.Top+3, jobs[ACol-1]);
end
seriesIndex:=(ARow-1) + length(days)*(ACol-1);
CustomLegendTool.Grid.Canvas.Pen.Style:=psClear;
CustomLegendTool.Grid.Canvas.Brush.Color:=Chart1[seriesIndex].Color;
CustomLegendTool.Grid.Canvas.Rectangle(Rect);
TeeDrawCheckBox(Rect.Left+39, rect.Top+3, CustomLegendTool.Grid.Canvas, Chart1[seriesIndex].Active, clWhite);
CustomLegendTool.Grid.Canvas.Pen.Style:=psSolid;
CustomLegendTool.Grid.Canvas.Brush.Color:=clNone;
procedure TForm1.ClickTool(Sender:TAnnotationTool; Button:TMouseButton; Shift: TShiftState; X, Y: Integer);
var seriesIndex, nCol, nRow: Integer;
with CustomLegendTool.Grid do
MouseToCell(X-ColWidths[0], Y-RowHeights[0], nCol, nRow);
if (nCol > 0) and (nCol<CustomLegendTool.Grid.ColCount) and
(nRow > 0) and (nRow<CustomLegendTool.Grid.RowCount) then
seriesIndex:=(nRow-1) + length(days)*(nCol-1);
Chart1[seriesIndex].Active:=not Chart1[seriesIndex].Active;
- customlegend.png (21.33 KiB) Viewed 7613 times
Posted: Thu Mar 21, 2013 2:31 pm
by 16464672
My word Yeray, I think that is one of the most beautiful things I have ever seen, you should add that to your demos.
I will take your sample code and seek to make the same work in my applications.
Many many thanks
Rob
Posted: Thu Mar 21, 2013 2:45 pm
Hi Rob,
Thanks for the compliments, but the idea is actually yours
We'll take your word and we'll add it to the demos.
