Hello Support Team,
we have several projects with teechart and speedbuttons on the TChart surface.
Using Delphi XE2 (please try the attached sample) the Chart (left one) freezes after pressing the speedbutton
(speedbutton property transparent=False). Please try to zoom and nothing happens...freezes
The Chart (right one) did not freeze after pressing the speedbutton (speedbutton property transparent=True).
Zoom and unzoom works fine...and after many (ca. 100) zoom and unzoom actions the Chart also freezes.
Did you have any ideas how to fix this issue?
System info:
Windows 7 64 bit
Delphi XE2
TeeChart
Release Notes 5th November 2012
TeeChart VCL version 2012
Build 2012.07.121105
Best regards from IAT Berlin
Freeze after Zoom Speedbutton
- Test_TeeChart.zip
- Sample with two charts. Left one freezes after clicking the speedbutton.
- (83.39 KiB) Downloaded 316 times
Re: Freeze after Zoom Speedbutton
Hi Dive,
Thanks for reporting. I could reproduce the issue here and added it (TV52016411) to the defect list to be investigated.
Not for now. As a workaround you could use a TButton instead of a TSpeedButton.Did you have any ideas how to fix this issue?
