Page 1 of 3
Last Installer for XE3 does not work
Posted: Sun Oct 28, 2012 2:46 pm
by 16561999
I've just tested pre-release for XE3, at the end of installation I got message: "The installation was aborted by the user. Run TeeInstall or TeeRecompile to install the package at a later time . Compilation aborted."
The log file is empty.
After that I tried to start TeeInstall and got message:
"Do you want to INSTALL TeeChart Pro? 2012 in RAD XE3.Win32 v17 Architect(RAD XE v10 Architect)(C++)?"
After pressing of the OK button I got the same first message (The installation was aborted by the user .... Compilation aborted.).
Re: Last Installer for XE3 does not work
Posted: Sun Oct 28, 2012 3:14 pm
by 16561999
After first step (see previous message) I've tested the source code installer for XE3, all steps were passed fine, only I had to made additional actions to put into operation TeeChart for C++Builder XE3:
1. $(TEELIBPATH) and $(TEEINCPATH) were updated by installer, this is OK.
2. for C++ libraries path I had to add $(TEELIBPATH) and $(TEELIBPATH)\Obj
3. for C++ include path I had to add $(TEEINCPATH)
After that C++ applications were compiled fine.
I've tested also FMX, the invisible controls bug is absent, at least this time.
Posted: Tue Oct 30, 2012 9:12 am
anauta wrote:I've just tested pre-release for XE3, at the end of installation I got message: "The installation was aborted by the user. Run TeeInstall or TeeRecompile to install the package at a later time . Compilation aborted."
We'd need some extra information to reproduce this here.
You are getting the message above with the binary installer, right?
What OS are you running?
Posted: Tue Oct 30, 2012 11:07 am
by 16559102
Yes, I got this message from binary installer, I am using win-32.
Source code installer works fine, except of writing paths for the CbuilderXE3, see my previous message.
P.S. My XE3 was installed without TeeChart Standard, may be this is a tip?
Posted: Tue Oct 30, 2012 11:24 am
vlezhu wrote:Yes, I got this message from binary installer, I am using win-32.
Windows 7 32bit? Or XP, 2008, 2003?
vlezhu wrote:Source code installer works fine, except of writing paths for the CbuilderXE3, see my previous message.
That's a known issue already present in the wish list to be fixed in future versions.
vlezhu wrote:P.S. My XE3 was installed without TeeChart Standard, may be this is a tip?
What exact XE3 version is this one that doesn't include TeeChart Standard?
Posted: Tue Oct 30, 2012 5:43 pm
by 16561999
Sorry, Win7-32 (aka x86)
I've installed XE3, but TeeChart was uncheked during installation of the Rad Studio.
Posted: Wed Oct 31, 2012 9:13 am
Thanks for the information. To summarize (correct me if I'm wrong anywhere):
- You got the "Compilation aborted" error message when running the v2012.07 PreRelease binary installer for XE3 in a Win7 32bit machine.
- The same error appears when running TeeInstall manually.
On the other hand, the SoureCode installation seems to work fine for you. I assume you've ran TeeRecompile, not just the installer.
Could you please try to run the TeeInstall utility generated by TeeRecompile? It should be in the "Compiled\Delphi17.win32" folder. If the installation made by TeeRecompile ended without that error message, executing it manually should also end successfully, but worth to check it.
The strange here is that the same binary installer works fine for us in both Win7 32bit and 64bit machines. This makes me think it should be something specific in your system that would be blocking some operation of the installer. But I'm not sure what could be blocking an operation from the binary installer and not the same operation from TeeRecompile's TeeInstall.
Posted: Wed Oct 31, 2012 2:19 pm
by 16463904
exactly the same behaviour for me,
with Windows 7 64-bit,
Where is TeeRecompile ?
Thanks, Minas
Posted: Wed Oct 31, 2012 3:15 pm
Hi Minas,
TeeRecompile is only included with the Source Code installations. It's a tool designed to help compiling and installing the sources in the supported IDEs.
If you are you running any security software that may be blocking something on the installer, please make sure to disable it and try it again. Check also you run the installer with high privileges.
We'll do more tests to see if we can reproduce it here.
Posted: Wed Oct 31, 2012 4:33 pm
by 16561999
I've tested TeeInstall from source code pack (I've uninstalled TeeChart for the beginning) and after that TeeInstall, now it works fine.
But now I can't repeat the error with Install from binary installer, may be this error can be visible on the fresh RAD Studio.
Posted: Wed Oct 31, 2012 4:51 pm
Hi Anauta,
We've just made a test in a fresh XE3 installation in a Win7 32bit machine, and no error has been prompted.
If you (or anyone) find a way to reproduce the problem consistently, we'll be glad to take a look it.
Posted: Wed Oct 31, 2012 5:41 pm
by 16463904
so i have windows 7 64-bit, Delphi XE3 Professional yesterday installation, McAfee antivirus that i closed it and the firewall etc, TeeChart for XE3 without source code.
I am running TeeInstall (run as administrator) and i see the known message. Any other idea, what to do ?
Posted: Wed Oct 31, 2012 7:21 pm
by 16459802
At me the same problem at installation, as at Anauta: " The installation was aborted by the user. Run TeeInstall or TeeRecompile to instal the package at a later time. Compilation aborted. ". OS win 7 32bit and fresh win7 64 bit, RAD XE3 Pro.
Posted: Thu Nov 01, 2012 8:56 am
by 16561481
I've just tested pre-release for XE3, at the end of installation I got message: "The installation was aborted by the user. Run TeeInstall or TeeRecompile to install the package at a later time . Compilation aborted.":
Error message
The log file is empty:
Empty log file
After show message:
The installation successfully completed
OS: Windows7 x64 Home Premium.
Rad Studio XE3 Professional.
Posted: Thu Nov 01, 2012 9:44 am
by 16463897
I got exactly the same error! Windows 7 pro/64, Rad XE3 Pro.
