Compiler exceptions with 2012.06 (120613)
Posted: Thu Aug 30, 2012 12:07 am
by 10546565
I am trying to run TeeCompile.exe for installing Tee Chart. I get the following log with exceptions:
FMXTee916
Cannot recompile Delphi package: FMXTee916.dpk
Embarcadero Delphi for Win32 compiler version 23.0
Copyright (c) 1983,2011 Embarcadero Technologies, Inc.
FMXTee.Chart3D.pas(124) Error: E2147 Property 'OnMouseEnter' does not exist in base class
FMXTee.Chart3D.pas(125) Error: E2147 Property 'OnMouseLeave' does not exist in base class
FMXTee.Chart3D.pas(747) Error: E2003 Undeclared identifier: 'SubdivisionsAxes'
FMXTee.Chart3D.pas(804) Error: E2003 Undeclared identifier: 'SubdivisionsAxes'
FMXTee.Chart3D.pas(1454) Error: E2003 Undeclared identifier: 'SubdivisionsAxes'
FMXTee.About.pas(407) Fatal: F2063 Could not compile used unit 'FMXTee.Chart3D.pas'
EXCEPTION:
Compilation aborted.
Any thoughts of what I might look at?
Ed Dressel
Re: Compiler exceptions with 2012.06 (120613)
Posted: Thu Aug 30, 2012 9:24 am
Hi Ed,
The easiest solution is to unselect the "Tee 3D" option in TeeRecompile if you are not going to use it.
Posted: Thu Aug 30, 2012 2:01 pm
by 10546565
It is unchecked. I have no options in the top-right corner checked.
Posted: Fri Aug 31, 2012 8:27 am
Hi Ed,
This is how it ends for me selecting the 4 Rad XE2 environments (Win32, Win64, MacOSC and iOS), and nothing else selected:
If you modified the v2012.06 sources, the problem may be due to these changes.
Posted: Fri Aug 31, 2012 2:22 pm
by 10546565
I haven't touched the install source.
Here are the settings I am using:
Here is the log:
TeeChart Pro
Compilation started: 8/31/2012 7:19:02 AM
RAD XE2.Win32 v16 (RAD XE v9 Enterprise)
Tee916
73643 lines, 0.61 seconds, 658480 bytes code, 4192 bytes data.
TeeUI916
60489 lines, 0.42 seconds, 438204 bytes code, 1112 bytes data.
TeeDB916
7546 lines, 0.38 seconds, 61304 bytes code, 284 bytes data.
TeePro916
173122 lines, 1.00 seconds, 1163992 bytes code, 6396 bytes data.
TeeGL916
13955 lines, 0.23 seconds, 117384 bytes code, 3072 bytes data.
TeeImage916
19482 lines, 0.22 seconds, 241356 bytes code, 11324 bytes data.
TeeWorld916
2170 lines, 0.19 seconds, 17576 bytes code, 268 bytes data.
TeeLanguage916
78227 lines, 0.45 seconds, 3384704 bytes code, 3520 bytes data.
DclTee916
7510 lines, 0.89 seconds, 130868 bytes code, 348 bytes data.
DclTeePro916
10352 lines, 0.66 seconds, 177852 bytes code, 508 bytes data.
DclTeeProStd916
6838 lines, 0.53 seconds, 174820 bytes code, 500 bytes data.
FMXTee916
EXCEPTION:
Posted: Mon Sep 03, 2012 1:46 pm
Hi Ed,
Do you have the Update 4 and the Hotfix 1 installed in your Rad XE2?
http://cc.embarcadero.com/item/28881
http://cc.embarcadero.com/item/28882
