Can I only export active series to a text file.
MarcelIbis
Post by MarcelIbis » Wed Jul 25, 2012 8:16 am
I'm using the TSeriesDataText to export the data to a text (csv) file. The user can activate and de-activate the series and wants only the active series to be exported.
I noticed that all the series (active and de-active) are exported to the text file.
Is there a way to only export the active series.
Marcel
Re: Can I only export active series to a text file.
Post by Yeray » Thu Jul 26, 2012 9:31 am
Hi Marcel,
MarcelIbis wrote:Is there a way to only export the active series.
I'm afraid not. However you can always do you own exportation method.
MarcelIbis
Post by MarcelIbis » Mon Jul 30, 2012 8:47 am
Hello Yeray,
Thanks for your reply.
I noticed that in the TChartEditor component you have the oportunity to select all sereies or select one serie (see tab Export, Data).
Can this code not be used to add only the active series to the TSeriesDataText component?
If yes, do you have an example how to add series to the TSeriesData component?
I noticed also that the help file Tchart8.hlp is (very) old. Is there a new version available?
Marcel
Post by Yeray » Tue Jul 31, 2012 8:39 am
Hi Marcel,
MarcelIbis wrote:I noticed that in the TChartEditor component you have the oportunity to select all sereies or select one serie (see tab Export, Data).
I'm afraid not. This is how it's made in TeeStore:
  if Assigned(Series) then
     DoSeries(Series)
  for t:=0 to Chart.SeriesCount-1 do
      DoSeries(Chart[t]);
Changing the code above for this works as you wish:
     DoSeries(Series)
      if Chart[t].Active then DoSeries(Chart[t]);
But applying this change would break the backwards compatibility. So we should probably add a boolean to control if the Chart[t].Active should be considered or not (not by default, as always).
I've added it to the wish list.
MarcelIbis wrote:I noticed also that the help file Tchart8.hlp is (very) old. Is there a new version available?
Do you see this file in an actual installation of TeeChart VCL v2012.06? I can only find a TeeChart2012.hlp in the Docs folder into the TeeChart installation.
Post by Yeray » Tue Jul 31, 2012 9:16 am
Hi Marcel,
Alternativelly, we could make the Series property in TSeriesDataText to accept an array of series. This would allow the user to export only the desired series. This would be more flexible.
MarcelIbis
Post by MarcelIbis » Wed Aug 01, 2012 12:52 pm
Hello Yeray
Thank you for your suggestions to improve the export function.
For the time being I use the following workarround:
I delete the non active series before the export as shown below.
Than create the series again.
for i := Chart.SeriesList.Count -1 downto 0 do begin
if not Chart.Series.Active then
Chart.Series.Free;
ExcelData := TSeriesDataText.Create(Chart, nil);
try
ExcelData.TextDelimiter := ';';
ExcelData.IncludeLabels := True;
ExcelData.IncludeHeader := True;
ExcelData.ValueFormat := '0.000 E+0';
ExcelData.SaveToFile(Datafile);
finally
ExcelData.Free;
MakeSeries.
Marcel
Post by Yeray » Wed Aug 01, 2012 1:36 pm
Hi Marcel,
Right. And instead of removing and recreating the inactive series, you could move them into a temporal list and restore them after exporting the series.
Here it is an example.
However, if you want the order of the series to be maintained, you should improve it.
uses Series, TeeStore;
var i, j: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.CheckBoxes:=true;
  for i:=0 to 5 do
    with Chart1.AddSeries(TBarSeries) do
      Title:='Series nº' + IntToStr(i+1);
      Color:=OperaPalette[i mod Length(OperaPalette)];
      Marks.Style:=smsValue;
      Active:=(i mod 2 = 0);
      for j:=0 to 5 do
        Add(random*75+25, 'Value nº ' + IntToStr(j+1));
  ExportActiveSeries;
procedure TForm1.ExportActiveSeries;
var i: Integer;
    tmpSeriesList: TChartSeriesList;
  tmpSeriesList:=TChartSeriesList.Create;
  for i:=Chart1.SeriesCount-1 downto 0 do
    if not Chart1[i].Active then
      tmpSeriesList.Add(Chart1[i]);
      Chart1[i].ParentChart:=nil;
  with TSeriesDataText.Create(Chart1) do
    IncludeHeader:=true;
    IncludeLabels:=true;
    ValueFormat:='0.000 E+0';
    TextDelimiter:=';';
    SaveToFile('C:\tmp\testExport.csv');
  for i:=tmpSeriesList.Count-1 downto 0 do
    tmpSeriesList[i].ParentChart:=Chart1;
MarcelIbis
Post by MarcelIbis » Wed Aug 01, 2012 3:15 pm
Hello Yeray
Your workarround works great. :D
Saves time to create and fill the series again!
One minor detail, I had to include the TeEngine unit in the uses clause for version 8.
Thanks for the grear service.
Marcel
Post by Yeray » Thu Aug 02, 2012 10:48 am
Hi Marcel,
I'm glad to hear it works and you like it! :)
David Berneda
Post by David Berneda » Tue Dec 03, 2013 2:30 pm
A new property in TSeriesData class has been introduced to allow exporting only a selected list of Series.
http://bugs.teechart.net/show_bug.cgi?id=243
This wish has been implemented, at the base class TSeriesData (TeeStore.pas unit), so all derived export format classes now have a new property (an array of Series) to filter which Series should be exported.
This applies to TSeriesDataText (txt, csv), TSeriesDataXML (xml), TSeriesDataHTML (html <table>), TSeriesDataXLS (Excel) and TSeriesDataJSON (json).
Usage example:
uses TeeStore;
var data : TSeriesDataText;
data:=TSeriesDataText.Create(Chart1);
data.IncludeHeader:=True;
data.SeriesList.Clear;
// Add only the Series you want to export:
data.SeriesList.Add(Series3);
data.SeriesList.Add(Series5);
data.SeriesList.Add(Series6);
Memo1.Text:=data.AsString;
data.Free;
MarcelIbis
Post by MarcelIbis » Wed Dec 04, 2013 11:59 am
Hello David,
Great! Thanks for this update.
Could every wish of me being solved this way. :wink:
In which version is this implemented?
Marcel Horsthuis.
Post by Narcís » Mon Dec 09, 2013 12:09 pm
Hi Marcel,
MarcelIbis wrote: In which version is this implemented?
Not a public version yet but the next maintenance release. It will be announced in this forum and other Steema Software channels as well.
