HTML5 export as active charts
jls
Post by jls » Wed Jun 27, 2012 8:15 am
Is it possible to export a VCL chart HTML 5 canvas like this:
http://www.steema.com/files/public/teec ... salign.htm
If I export it from the edit dialog the result is an inactive chart like in the attachment.
TeeChart for Javascript is available as a standalone product and as an export format across the
TeeChart product range. Both formats enable HTML5 live in-browser charts as a visualisation format
for a selected range of TeeChart data series types. Other series types, not supported in the
dynamic model, may be output to browsers as static HTML5 charts. See http://www.w3.org/TR/html5 for more
details of the HTML5 specfication.
rr.zip
(4.38 KiB) Downloaded 509 times
Re: HTML5 export as active charts
Post by Yeray » Thu Jun 28, 2012 1:57 pm
I'm afraid the TeeJavascript (.dcu and .dfm) wasn't shipped with this release. It will be included in the next one. However, if you tell us what IDE are you using, we could attach here the required files to allow this exportation.
jls
Post by jls » Fri Jun 29, 2012 7:23 am
Using XE2 update 4
Can you send me the source code on email ?
Jørgen
Post by Yeray » Fri Jun 29, 2012 8:38 am
Hi Jørgen,
Right, you are source code customer. So you already have that sources.
Sorry, I didn't explain myself clearly enough. The v2012.06 packages don't include the references to the TeeEquiVolume, TeeEquiVolEdi and TeeJavascript units. So the binary installers don't include the according dcu and dfm. But the pas and dfm are included in the Source Code version so you should be able to use them.
Anyway, we've already corrected the packages so I'll send you the modifications.
